Author Topic: Wired stabilizers good ? Bad?  (Read 2657 times)
Offline GODJOEY
    • Site
« on: Mon, 19 March 2012, 13:07:15 »
Hello first off thank you for such a great site I just recently purchased a Filco cherry mx black recently after a lot of research on this site. I just picked up a Leopold cherry mx red and I noticed immediately the larger buttons some not all have no bottoming clack and more of a mushy feel. I contacted elitekeyboards and they stated they are using wired stabilizers and may be a little stiff but will loosen up. I notice on the Filco all the keys feel and sound the same compared to my leopold not bad but is this something that can loosen up later or will I have to possibly grease it as the support stated. I saw in one of the reviews that the leopolds were using cherry mx stabilizers this is the only reason I'm asking.
"These larger keys have wire stabilizers in them that might be a little
stiff. The tend to loosen up over time, but may need some grease. We can
send you some if you're interested." - Elitekeyboards.com
Offline Ahlitah
« Reply #1 on: Mon, 19 March 2012, 13:24:24 »
since when do Leopolds have wire stabalizers?
They use Cherry Style stabalizers.
Costar on the other hand uses Wire stabilizers! which is whats in your Filco.
Offline GODJOEY
    • Site
« Reply #2 on: Mon, 19 March 2012, 14:07:50 »
Thank you ripster for your welcome, thank you Ahlitah for the info. Any pros and cons on either one durability?
Offline miscreation
« Reply #3 on: Mon, 19 March 2012, 14:14:35 »
Quote from: Ahlitah;550664
Cherry Stabilizers have a wire that connects the two posts that go into the keycap.
As for the stabilized keys on the Leopolds, I rather like the way they feel, though I use the brown switch on both of mine.  After my first one developed a squeak on the left shift key, I put some grease on it and cleared it up--but it didn't really change the feel of the switch any.
« Last Edit: Mon, 19 March 2012, 14:27:27 by miscreation »
Offline megnin
  • Topre, or not Topre? That is the question.
« Reply #4 on: Tue, 20 March 2012, 19:48:28 »
"Nothing here is what it seems."
Here is a Filco with Cherry stabilizers, not Costar wire stabilizers.
[ Attachment Invalid Or Does Not Exist ] 45134[/ATTACH]
This is my Bluetooth Filco with MX Browns that I got three or four years ago.  I just tonight received a new space bar to replace the the shiny one on it and when I removed the old space bar I was shocked to see Cherry stabilizers.
“The only difference between me and a madman is I'm not mad." -- Salvador Dali
Offline sordna
« Reply #5 on: Tue, 20 March 2012, 20:36:22 »
I didn't like the different feel of cherry-stabilized keys in my Poker, and my solution was to put 50A durometer o-rings on the rest of the keys. It actually resulted in an almost perfectly homogenous feel! No more clack clack thud, clack clack thud. It's thud, thud, thud. Gotta have either all clacks, or all thuds in a keyboard ... consistency is important for a good-feeling keyboard!
Offline Human
« Reply #6 on: Tue, 20 March 2012, 21:38:49 »
Quote from: megnin;551867
(Attachment Link) 45134[/ATTACH]
And the stem spacing is similar to the one found in SS7G and Leopold 200R?
Offline megnin
« Reply #7 on: Tue, 20 March 2012, 21:47:06 »
I just yanked a space bar off a Leopold 200R and the stem spacing it identical.
Offline REVENGE
« Reply #8 on: Tue, 20 March 2012, 21:57:10 »
BT Filco was probably not Costar.
Offline Zamorph
« Reply #9 on: Tue, 20 March 2012, 22:04:18 »
From what I hear, cherry gets more life, but I have not seen costar's style break soo...
