Author Topic: difference between personal and professional datahand versions  (Read 1196 times)
Offline kamaraju
Any one knows if there is a difference between buying a personal edition datahand and installing the pro II upgrade (available in http://datahand.com/products/accessories.htm ) instead of buying the pro II version directly?
thanks
raju
Offline Input Nirvana
« Reply #1 on: Mon, 19 March 2012, 22:10:26 »
When you buy the upgrade, they send you the chip and the Pro Ii templates. Once you install, it is the same exact unit as they send as a Pro II. No difference. Lynn at Datahand will confirm.
