Author Topic: KBC Poker Modification For Echo Sound  (Read 1297 times)
Offline Changdrew
« on: Thu, 22 March 2012, 02:50:27 »
[video=youtube;bdKveb39U3c]http://www.youtube.com/watch?v=bdKveb39U3c[/video]
In this video, he basically just types, but I noticed that the sound was a lot different, cleaner somehow.
In the description, he says that he put something below the pcb and on top of the housing to fill up the space to rid the sound of the echo and to make it sound a lot better.
So basically my question is, How do you do this?
If one of you guys posted this, I would appreciate it if you told me how you did it :D
CM Quickfire Rapid | Filco Majestouch 2 | Filco Linear R | Poker
Offline WhiteFireDragon
    • youtube
« Reply #1 on: Thu, 22 March 2012, 02:56:19 »
Most likely foam or some kind of padding to dampen the sound.
I did this with the poker I got from you, although it's to make it more sturdy instead of dampening the sound :D
Offline Changdrew
« Reply #2 on: Thu, 22 March 2012, 03:01:29 »
Hmmmm sounds good. Once I get my blue poker, I'll test this out. I'm probably going to do this with my cm storm, since I noticed that echoes too lol
