Author Topic: .  (Read 8902 times)
Offline dante
« on: Thu, 22 March 2012, 22:38:59 »
« Last Edit: Tue, 21 August 2012, 12:02:59 by dante »
Offline bazemk1979
[CLOSED] Keycool 87 w/ Cherry Clear switches
« Reply #1 on: Fri, 23 March 2012, 00:27:18 »
does it uses costar stabilizers like filco? im interested in it cause of the switches
« Reply #2 on: Fri, 23 March 2012, 00:33:54 »
its a leopold clone
[STRIKE]so, cherry stabilizers[/STRIKE]
costar stabilizers.
« Last Edit: Fri, 23 March 2012, 00:43:21 by demik »
Offline Changdrew
« Reply #3 on: Fri, 23 March 2012, 00:35:04 »
The 2011 version in reds I have has costar stabilizers o_O
CM Quickfire Rapid | Filco Majestouch 2 | Filco Linear R | Poker
« Reply #4 on: Fri, 23 March 2012, 00:43:01 »
i take that back.
it does have costar stabilizers.
Offline Human
« Reply #5 on: Fri, 23 March 2012, 01:22:49 »
Quote from: bazemk1979;554319
Yup, Costar style, but I definitely sure it is not made by Costar. The good part with that keyboard is that it is provided with lots spare parts(extra keycaps, stabiliser insert and even stabiliser mount on the steelplate) right out of the box.
In case you need review on it, do visit the review section for its review.
Offline Human
« Reply #6 on: Fri, 23 March 2012, 01:23:41 »
Quote from: demik;554337
i take that back.
Only the very first few batches of Keycool 104(fullsize) having Cherry stabiliser, all their other products use Costart style.
Offline csm725
  • I BLEED RED AND GOLD
    • http://csm725.com
« Reply #7 on: Fri, 23 March 2012, 02:55:56 »
Does the Keycool have a Leo or Filco/Ducky spacebar?
If Fil/Duck, I'm in for one, preferably with a white body.
« Last Edit: Fri, 23 March 2012, 03:02:54 by csm725 »
Offline Human
« Reply #8 on: Fri, 23 March 2012, 07:55:01 »
Quote from: csm725;554401
Sadly no, Keycool is following the spacebar standard on Leopold FC500R. Though, spacebar from Noppoo Choc Pro and Neo Zelia 87 should be universal compatible on all Costar wire style stabiliser keyboard, including keycool.
Though, some rumors say that their upcoming Backlit Tenkeyless will using a new and normal standard spacebar, not too sure.
« Last Edit: Fri, 23 March 2012, 07:58:27 by Human »
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #9 on: Fri, 23 March 2012, 08:50:01 »
Put me down for a clear
Sent from a phone...
-Enzo Ferrari
Offline Human
« Reply #10 on: Fri, 23 March 2012, 09:07:20 »
Quote from: boost;554565
They don't have CLEAR(actually they do have, just that it is LIMITED EDITION and cost around 20USD more than other switch variant).
Offline Human
« Reply #11 on: Fri, 23 March 2012, 09:08:50 »
Quote from: dante;554527
Two options: TheProfosist could probably mod a space bar for you.  Also, if that is not enough and you are seriously interested I can see what it would take to also include space bars as an optional item on the side.
There is exclusive colorful(6colors and another 2 for black and white) spacebar for Keycool in taobao. What the person I quoted is that he afraid he can't change the spacebar when he get a whole set replacement that spacebar don't fit.
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #12 on: Fri, 23 March 2012, 10:02:25 »
Quote from: Human;554580
I meant cherry mx clear
-Enzo Ferrari
Offline Human
« Reply #13 on: Fri, 23 March 2012, 11:34:51 »
Quote from: boost;554620
So am I. Keycool's Cherry Clear version is marketed as their year 2012 limited edition at 488RMB(normal version range from 340-370RMB).
Offline bazemk1979
« Reply #14 on: Sat, 24 March 2012, 09:08:34 »
Quote from: Human;554582
its the only drawback for me about these boards, also the same case with Leopold.
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #15 on: Thu, 29 March 2012, 01:00:12 »
i'm interested in a white at the 70 price point shipped. bummer about the space bar though.
Offline csm725
    • http://csm725.com
« Reply #16 on: Thu, 29 March 2012, 03:06:36 »
Yup, white would be good.
Hope OP delivers and we get this GB going soon...
« Last Edit: Thu, 29 March 2012, 03:52:09 by csm725 »
Offline thegunner100
  • (╯'□')╯︵</3 ノ( '-'ノ)
    • The Emotional Skyscraper
« Reply #17 on: Thu, 29 March 2012, 07:33:52 »
Interested as along as the Q.C problems are gone.
Edit: White case
Input Devices:CM QF Rapidx2 ~ REALFORCE 87uw 45/55g ~ Logitech G5v2 ~ Wacom Bamboo CTH-460
Audio Setup: look me up on head-fi
Check out my blog on touhou/doujin music, audiophile gear, and doujin games!
Offline Human
« Reply #18 on: Thu, 29 March 2012, 09:59:44 »
Quote from: dante;560369
so far:
boost
[strike]human[/strike]
mkawa
thegunner100
plus me which makes five.
It looks like everyone is interested in the white so that is what we will stick with for simplicity sake.  Ideally I'd like to see 5 more buyers for purchasing power but if we can't I'll see what I can do.
I can't guarantee the will have costar stabs (supplier won't open boxes to check.)  It sounds like by now they should all be costar - not a guarantee however!
Just some fix. Actually I own a Keycool already, so don't include me in the IC, thanks.
BTW, if you are getting 87(TKL), you can rest assured that it is Costar style stabiliser.
Offline csm725
    • http://csm725.com
« Reply #19 on: Thu, 29 March 2012, 13:55:08 »
Nevermind; not in.
« Last Edit: Thu, 29 March 2012, 14:04:28 by csm725 »
Offline mkawa
« Reply #20 on: Thu, 29 March 2012, 14:59:22 »
thanks for the update dante. too bad about the boards.
