Author Topic: Happy hacking keycaps  (Read 1908 times)
fossala
  •  Guest
« on: Sun, 25 March 2012, 14:56:56 »
Can someone with a white HHKB and a black HHKB show me what a white HHKB would look like with black modifiers? Blank prefebly but will kind of get an idea either way. For bonus points if you have a red esc throw that on there as well.
Just want to see what it would look like before I buy the caps.
Cheers.
Offline frankfrank
« Reply #1 on: Mon, 26 March 2012, 03:39:39 »
Cheers up!
Offline oneproduct
  • @Ubisoft
« Reply #2 on: Mon, 26 March 2012, 10:10:26 »
Where did those metal keycaps come from?
Layout: Colemak
Offline canthonytucci
« Reply #3 on: Mon, 26 March 2012, 10:36:29 »
I can do it when I go home, by modifiers do you mean just ctrl, shift, command and option, or all the surrounding non-letter/number keys?
[SIGPIC][/SIGPIC]
Offline megnin
  • Topre, or not Topre? That is the question.
« Reply #4 on: Mon, 26 March 2012, 11:03:56 »
I don't know if this is exactly the layout your are looking for.  I tried it with just the modifiers, but liked it better this way.  I may even finish swapping them so the white one has all black keys and vise versa.
[ Attachment Invalid Or Does Not Exist ] 45811[/ATTACH]
“The only difference between me and a madman is I'm not mad." -- Salvador Dali
fossala
  •  Guest
« Reply #5 on: Mon, 26 March 2012, 14:12:13 »
Thanks, I don't like it. I will just keep it white.
Offline Squelos
« Reply #6 on: Mon, 26 March 2012, 14:31:20 »
HHKB, do nothing but type. No arrows/Home/pg up, pg down.
It really is a whole concept when you think of it.
Offline whiskerBox
« Reply #7 on: Mon, 26 March 2012, 14:46:34 »
Quote from: Squelos;557466
You are SO WRONG!!!
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
Offline megnin
« Reply #8 on: Mon, 26 March 2012, 15:46:18 »
Quote from: fossala;557452
I agree with you, so I think I'll finish switching the keys.  I do like all black keys on a white keyboard and vise versa.
fossala
  •  Guest
« Reply #9 on: Mon, 26 March 2012, 15:48:27 »
I like white keys on black boards but not the other way around.
Offline megnin
« Reply #10 on: Mon, 26 March 2012, 17:24:46 »
Since I just swapped the keys, this was the only option.  I think I like both of them.
[ Attachment Invalid Or Does Not Exist ] 45837[/ATTACH]
Offline sth
  • 2 girls 1 cuprubber
« Reply #11 on: Mon, 26 March 2012, 17:31:52 »
TIL:
I usually like white keys on black boards except in the case of the HHKB.
I usually do not like black keys on white boards except in the case of the HHKB.
