Author Topic: Power problem with IBM Model M2  (Read 1241 times)
Offline CammRobb
« on: Tue, 27 March 2012, 18:03:18 »
I got an IBM Model M2 last week, and it worked from the moment I plugged it in. Switched my computer off that night, and went to bed.
In the morning I switched my PC on, an my keyboard wasn't working. The Caps Lock and Scroll Lock lights are on, but no keystrokes are being registered. It's plugged in through PS/2 to a Gigabyte 990FX-UD3. I haven't got a PS/2 to USB adapter handy, but I've ordered one.
Has anyone had this problem or knows how to solve it?
CammRobb
Offline Soarer
« Reply #1 on: Tue, 27 March 2012, 19:31:20 »
Welcome to geekhack!
I've heard about capacitors needing to be replaced on M2s, but I don't know what symptoms would show up if they were bad - likely it varies. Sorry I can't be more useful, but maybe that helps you searching for more info.
Offline CammRobb
« Reply #2 on: Tue, 27 March 2012, 19:46:51 »
Quote from: ripster;558604
See the PS/2 compatibility wiki. Common problem at reboot.
Unlike some my comments are always useful if duly contemplated.
thanks for the replies guys,  ripster, I can't seem to figure where to go for the suggestion in the wiki, could you link me?
Offline mich
« Reply #3 on: Wed, 28 March 2012, 02:13:01 »
STFU noob
http://geekhack.org/showwiki.php?title=Island:5065
A capacitor in the delayed start circuit has dried up causing the microcontroller to start prematurely and fail.
Capslock and scrollock are lit up because they are driven through inverters and hence this is their default power-up state. The firmware would normally clear them after boot, but it crashes.
This can only be fixed by replacing this cap.
« Last Edit: Wed, 28 March 2012, 02:25:39 by mich »
Offline hella
« Reply #4 on: Wed, 28 March 2012, 03:40:54 »
M2's are notorious for their high failure rates as a result of the capicitor drying up.  Follow the link above.  Best of luck fixing it!
Offline ThePringler
« Reply #5 on: Wed, 28 March 2012, 10:57:17 »
Quote from: mich;558959
STFU noob
I wasn't sure if this was a joke or serious. Personally, i would never call someone a NOOB on a forum who has 54,000+ posts. Just saying.
