Author Topic: Kinesis Advantage - Center Number Pad [numpad] mod  (Read 7282 times)
Offline Keyboard search
« on: Tue, 27 March 2012, 18:37:30 »
Kinesis Advantage keyboard
Kinesis numpad  (Yep, it has Cherry MX Browns to match the Advantage)
So very glad I did not destroy my Kinesis in the process.
I bought some X-Acto knife/saws, and basically just hacked away room for it.
I'm very happy with it, but I would only recommend doing this if you are a MUDder.  Easiest way to walk in a MUD is with a number pad.  Only other use I can think of, is to make entering numbers (i.e. credit card number, phone number maybe, etc) easier.
I use my modded Kinesis Advantage (Black).  It has a Kinesis numpad between the halves.
Offline Input Nirvana
« Reply #1 on: Thu, 29 March 2012, 01:50:26 »
Heh heh FUN!
It is possible for a couple pics and/or a description of how you dealt with the mainboard?
Can I use a pic of it in the Gallery in my Split Kinesis mod wiki?
Offline sordna
« Reply #2 on: Fri, 30 March 2012, 18:36:04 »
yup, pics needed, inside and out !
