Author Topic: Looking for a keyboard with these features  (Read 2428 times)
Offline galerian
« on: Wed, 28 March 2012, 21:17:33 »
I'm looking for a keyboard with keys that don't wobble, uniform tactile and sound feedback, and reasonably quiet. Additional preferred but optional features: tenkeyless and rubber keycaps. Anyone know of such a keyboard?
Offline Erick_C
« Reply #1 on: Wed, 28 March 2012, 23:33:40 »
Quote from: galerian;559854
... and sound feedback, and reasonably quiet....
Um... is this kinda like "if a tree falls in the woods and no one is there to see it, does it make a sound" thing?
Offline Reptile
« Reply #2 on: Wed, 28 March 2012, 23:37:19 »
Sure lots of boards but rubber keycaps?
Home:Realforce 87UB 55g
Work:Leopold FC700R Ergo Clears
Offline galerian
« Reply #3 on: Thu, 29 March 2012, 07:53:34 »
Keycaps with rubber tops is what I meant. I don't really need them, but they'd be nice.
My issues with all the membrane and scissor switch kb's I've come across are wobbly keys and some keys are louder than others when pressed.
What boards do you have in mind, Reptile?
Offline Squelos
« Reply #4 on: Thu, 29 March 2012, 20:05:21 »
Not too noisy, but sound feedback ? Blues have sound feedback, buckling springs also, but they are pretty loud.
The blues are really high pitched also.
Could you do with browns (light tactile feedback) ?
When you say feedback, are you talking about feedback on actuation, or when bottoming out ? Mechs tend to bottom out pretty loudly, and you really feel it. not something you have on rubber domes (mushy mushy !).
How heavy would you like your keys ? Light, medium ? heavy ? Light is under 55g, 55g is medium, above 55g is heavy.
Just dont go for a Razer BlackWidow if you dont intend in changing they caps, they are quite wobbly. Once you change them, its pretty much perfect in that sense ...
Offline galerian
« Reply #5 on: Thu, 29 March 2012, 20:14:12 »
Not too noisy, preferably as quiet as possible, with even sound feedback across keys (meaning every key has about the same noise level when pressed).
I'm really looking for rubber dome boards, unless none of them have the features I specified. Mechanicals are kind of out of my budget.
I'd prefer light keys, as I'm used to typing on a scissor switch.
I don't intend on changing any key caps.
Offline Erick_C
« Reply #6 on: Thu, 29 March 2012, 20:38:19 »
You may be satisfied with a keyboard with ALPS keyswitches.  They're cheaper than Cherry MX keyswitch-based or Topre-based keyboards.  Mechanical keyboards offer the solidity, tactile, and sound feedback that you're looking for.
From the looks of this thread, Dante may be starting a GB for ALPS-based TKLs from Leopold Korea.  Something for your to consider.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #7 on: Thu, 29 March 2012, 20:43:12 »
Mechanical is only out of budget if you must buy new and under $70. You can get used MX boards for as little as $15 if you have some luck on ebay. Lots of Alps and other types there too. Sometimes even NIB for under $40.
There are even MX boards you can get retail for $75 or slightly less. What is your budget? How particular are you about layouts? etc, etc?
From what you say I think MX browns would be what you might be looking for, maybe clears. Though on the other hand, maybe linear as well, since you seem to be more focused on bottoming coming from domes.
Offline mrmusicmr
« Reply #8 on: Fri, 30 March 2012, 00:33:16 »
i am not sure.
Offline bader0
« Reply #9 on: Fri, 30 March 2012, 02:58:34 »
if you want no wobble in your keys probably stay away from keys with costar stabilizers as they tend to be more wobbly than ones with cherry stabilizers although the feel better imo. anyway if i were you i would get a leopold or something like that with browns. EDIT: just read the bit about the budget  what kind of budget are you looking at exactly?
« Last Edit: Fri, 30 March 2012, 03:02:11 by bader0 »
Offline galerian
« Reply #10 on: Fri, 30 March 2012, 08:22:35 »
Budget is around $50 and I'm really looking for a tenkeyless due to limited desk space. What do you mean by layout?
Offline Reptile
« Reply #11 on: Fri, 30 March 2012, 09:39:22 »
Quote from: galerian;561475
Wont have many options with $50 BUT you could get close to that with a CMstorm used. Which many people will agree that it's a solid board.
