Author Topic: KMAC with Red Alert set from sixty  (Read 89567 times)
Offline reaper
« Reply #100 on: Wed, 23 May 2012, 17:14:40 »
Yeah, I'm also a member there but doubt if I'll ever find one. lol
Din Eli
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #101 on: Fri, 25 May 2012, 09:44:44 »
i think the only way we're going to get access to the OTD stuff is if we make things that are even cooler than theirs and barter
Offline Djuzuh
« Reply #102 on: Fri, 25 May 2012, 09:45:37 »
me too !
When will phantom finish so we can launch another project? :D
Offline HolidaySHRIMP
« Reply #103 on: Fri, 25 May 2012, 09:57:11 »
Ok my friends gf lives in Korea and is coming next month. I need links to where I can buy this. My best friend is going again in September for his brother in laws wedding also. Wish I had known about keyboards when I went last June! My gf is korean and can translate for me.
Tldr give me links on where to buy.
I'll try to buy a few extras first time around. I'll buy a lot next time around.
Edit: looks like its not going to be easy lol
« Last Edit: Fri, 25 May 2012, 10:06:05 by HolidaySHRIMP »
Offline Djuzuh
« Reply #104 on: Fri, 25 May 2012, 10:01:33 »
Even if you are korean those boards are hard to get. Compare them to click clack keys on this forum.
You'll find more info in this thread:
http://geekhack.org/showthread.php?31628-Proxy-for-purchasing-Korean-keyboards-from-KBDMania-OTD-etc
Offline inlikeflynn
  • file not found
« Reply #105 on: Tue, 29 May 2012, 06:07:58 »
does anyone know what kind of stabilizers the winkey KMAC uses?
I've seen pictures of the winkeyless boards which have Cherry stabilizers, but nothing of the winkey boards.
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline litster
  • rare caps?! THAT'S A SMILIN
« Reply #106 on: Tue, 29 May 2012, 10:05:30 »
Same as winkey KMAC - Cherry PCB mount stabilizers.  The only different is the spacebar one.  Winkey spacebar is 6.25x wide.  Winkeyless spacebar is 7x wide.
Offline inlikeflynn
  • file not found
« Reply #107 on: Tue, 29 May 2012, 13:46:19 »
Quote from: litster;602782
Thanks lister! I just wanted to confirm to see if I needed the universal spacebar then as well from the Wyse GB
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline litster
« Reply #108 on: Tue, 29 May 2012, 15:02:04 »
I don't have a picture of the KMAC mounting plate and I don't have access to one now.  But on the KMAC winkey PCB, there are two positions for the spacebar switch.
BTW, who is lister?  Does he know demilk?
Offline inlikeflynn
  • file not found
« Reply #109 on: Tue, 29 May 2012, 15:06:36 »
Quote from: litster;603112
dammit :tape:
I have dyslexia today sorry about that litster
I am confused now though. Will a standard FILCO like 6.25 sparebar fit the winkey KMAC? Or does it need the newer style universal 6.25 sparebar to fit the winkey KMAC?
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
