Author Topic: Frist gaming keyboard?  (Read 2315 times)
Offline mrmusicmr
« on: Fri, 30 March 2012, 00:40:04 »
Hey guys,
I'm having trouble deciding on my first gaming keyboard, there are so many choices in the market,i am not sure.
my friend recommend me this gaming keyboard for me,he told me that is perfect for Call of Duty.what do u think about it?is it good?
And other recommendations?My budget is within $100.
Cheers
Offline PixelVandalism
    • YouTube
« Reply #1 on: Fri, 30 March 2012, 01:01:43 »
Get a quick fire rapid with reds.
Offline slueth
« Reply #2 on: Fri, 30 March 2012, 01:03:16 »
http://www.newegg.com/Product/Product.aspx?Item=N82E16823109191
For the Microsoft Sidewinder, its a rubber dome that is nkro.
If you want a mechanical keyboard I would suggest a cherry red or if you are manly a cherry black.  Rosewill, cmstorm, or leopold are around 100 or less.
Offline anselben
« Reply #3 on: Fri, 30 March 2012, 01:30:06 »
The quick fire rapid with reds seems like the best bang for your buck mech gaming keyboard right now.
Offline Erick_C
« Reply #4 on: Fri, 30 March 2012, 02:14:55 »
There's nothing wrong with that keyboard.
Most of the recommendations you're going to receive from here is going to be a mechanical keyboard.  Staying within your budget ($100) and your chosen vendor (newegg), I'd say:
1.  Rosewill Mechanical Keyboard RK-9000BL or 9000RE
The coolermaster website is the only place to get a CMStorm Quickfire Rapid with Cherry MX Red switches (aside from a used one somewhere here).  This keyboard should run you about $100 with shipping.
If you're willing to buy from overseas, there's plenty of vendors here that can offer you mechanical keyboards with Cherry MX Black Switches for less than $100.
There's a guy stuck with a bunch of Poker X keyboards.  Go to the "Group Buy" section and find him and take one of the ones with Black switches off his hands.
« Last Edit: Fri, 30 March 2012, 02:17:35 by Erick_C »
Offline Autolyze
« Reply #5 on: Fri, 30 March 2012, 06:30:43 »
I would also suggest one of the previously mentioned keyboards with MX Red or MX Black switches. It's really down to personal preference, but a lot of people (including myself) think that they're the way to go for FPS games in particular. The Rosewill, Quickfire Rapid, Leopold, and Poker are all quality boards and should be in your budget.
Offline Vancha
« Reply #6 on: Fri, 30 March 2012, 09:06:59 »
I can hear his friend now..."You idiot, why did you get that? It doesn't even have lights, or macro keys!"
Offline CaiSter21
« Reply #7 on: Fri, 30 March 2012, 09:28:28 »
^ LOL, "or a MW3 logo!"
Ducky Shine DK 9008S Red LED |Rosewill RK-9000BR
Offline Typhaeon
« Reply #8 on: Fri, 30 March 2012, 10:22:40 »
Don't be seduced by game branding, nor the epithet "gamer" attached to some overpriced piece of crap that'll blow on you within 3 months (not like that, you idiots).
Logitech dome keyboards don't last over time and feel like pounding your fingers into a wall.  I was in your situation a few years ago before I discovered Unicomp.
http://www.pckeyboard.com
Consider getting a buckling spring keyboard from them, or, as mentioned, a CMStorm Quickfire of some sort.  Rosewill distributes very solid boards as well.  Check the Great Deals forum.
Offline Erick_C
« Reply #9 on: Fri, 30 March 2012, 11:03:24 »
Quote from: Vancha;561503
If after seeing and using the Poker X they still feel like this... bring your friends to GH.  We'll straighten them out...
« Last Edit: Fri, 30 March 2012, 11:06:05 by Erick_C »
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #10 on: Fri, 30 March 2012, 11:06:08 »
As a gamer in many genres. I love having my "GG" macro, and my Pause->"G"->"T"->'"F"->"O"->Unpause macro. Gamers like that ****. The lights is just for decoration and I still like them.
But anyone who decides to use a Rubber Dome over a Mechanical need to be put down. BlackWiddow users too, depending on situation.
Fight For Freedom. Stand with Hong Kongers
Offline RColinTaylor
« Reply #11 on: Fri, 30 March 2012, 13:21:39 »
Get new friends.
I like my Browns more than my Blues.
