Author Topic: Looking for a cheap keyboard  (Read 1420 times)
Offline Nunez
  • BACK!
« on: Sat, 31 March 2012, 06:34:14 »
I'm currently using a Dell scissor dome keyboard at work and it gets annoying to type on reallllly quick.
I'm looking for a cheap Mechanical keyboard, not too concerned about the switch type.. preferably browns but doesn't really matter. ANSI layout, something like the TVS Gold keyboard would be great, though its ISO :(
So in short, I want it to be:
- Mechanical
- ANSI
- Fullsize
- Cheap
If you know anything suitable, I'd love to hear about it.
I miss Ripster :(
HHKB Pro 2 || KBC Poker || Filco MJ2
Offline thegunner100
  • (╯'□')╯︵</3 ノ( '-'ノ)
    • The Emotional Skyscraper
« Reply #1 on: Sat, 31 March 2012, 08:10:58 »
How "cheap" is cheap? Also, being in AUS is going to severely limit your options.
Input Devices:CM QF Rapidx2 ~ REALFORCE 87uw 45/55g ~ Logitech G5v2 ~ Wacom Bamboo CTH-460
Audio Setup: look me up on head-fi
Check out my blog on touhou/doujin music, audiophile gear, and doujin games!
Offline Nunez
  • BACK!
« Reply #2 on: Sat, 31 March 2012, 17:49:08 »
By Cheap, I'm trying to compare to the TVS Gold on ebay.
I miss Ripster :(
Offline bhtooefr
    • bhtooefr.org
« Reply #3 on: Sun, 01 April 2012, 08:18:58 »
To go TVS Gold cheap, you're gonna be looking at used stuff on eBay.
There's a couple Model Ms cheap on eBay AU, you might try that...
Either that, or just search for keyboard, and slog through all the rubber dome crap to find something mechanical. You might find some old Alps board, although a lot of that will have L-shaped enters.
