Author Topic: LASTLY, A MECH KEYBOARD WITH THE PERFECT LAYOUT + FOOTPRINT IS BORNED!!!!  (Read 49867 times)
Offline Human
Has anyone had any luck getting these yet?  Last few times i tried getting a white one with red switches the vendors were out.
I had gotten mine. Being quite busy lately so no time to write a detailed review on it.
In short, it is a nice board.
1. Wireless
2. Nice/Perfect layout and footprint
3. PBT/POM keycaps
4. Solid + heavy built despite being a PCB mounted board
5. Backlit ready by just adding your own LED
6. NKRO
7. Detachable wire
8. Multimedia shortcut keys and bla bla bla, literally everything you every asked for
The only cons is that...
It uses an odd spacebar standard, similar to Neo Zelia 87, and probably Keycool/Leopold FC500R also...
P/S: Those Blank keycaps are KBC POM which I purchased seperately.
« Last Edit: Sun, 21 October 2012, 02:10:12 by Human »
Offline Human
Jesus, and it costs US$ 60 on China! I'm soo getting one!
Link!!! What is it called?
PLUM96
Offline laffindude
Those POM keys looks really nice on it.
Offline TheQsanity
  • SmallFry Lovin'
1. Wireless
3. PBT/POM keycaps
6. NKRO
7. Detachable wire
Led ready?!?!?!  What da... this is so unreal.  Shortcuts????!!!
SmallFry! <3
Offline Human
1. Wireless
3. PBT/POM keycaps
6. NKRO
7. Detachable wire
Yup, it come with holes and circuit for LED, just mount it yourself and you are good to go. Shortcut keys mean those Volume control, play/pause, Computer and so on.
Offline Cindori
    • My Blog
Uhm wait a seconddddd
It's WIRELESS, MECHANICAL, NKRO, with DETACHABLE WIRE, and LED support, and it cost $70 USD!?!?!?
« Last Edit: Sun, 21 October 2012, 03:18:32 by Cindori »
Offline TheQsanity
  • SmallFry Lovin'
Haha that made me laugh.
Now the question is... black or white.. your white ones look a lillte cream. Are they clear white? What would look better with leds?
I haven't done an led mod yet. Should any led work? Does it have a manual that says?
SmallFry! <3
Offline Human
The keycaps are perfectly bright and clear white. The case is a little cream clay/greyish, not too much a problem.
If I am you, I will go for blackcase but white keycaps. Because white color case are prone to yellowing after long term use, worsen when exposed to sunlight(which is inevitable at my country). White keycaps are PBT, which are really comfort to touch on.
White color normally looks better with custom keycaps(rainbow especially).
For LED mod, it is normally discussed in China KB forums. There isn't any manual(except the one which explain the keys layout) inside. I had asked around and the answer I got is that board should use a 2.8V LED(that mean 3V should be OK?). Though, I am not reponsible if anything wrong with your board.
www.waishehome.cn/forum.php?mod=redirect&goto=findpost&ptid=45648&pid=1043760
« Last Edit: Sun, 21 October 2012, 04:34:32 by Human »
Offline Cindori
    • My Blog
Re: LASTLY, A MECH KEYBOARD WITH THE PERFECT LAYOUT + FOOTPRINT IS BORNED!!!!
« Reply #108 on: Sun, 21 October 2012, 04:52:38 »
It is a normal 3mm led. Just search "3mm led" on ebay.
Offline Human
« Reply #109 on: Sun, 21 October 2012, 05:14:29 »
The wattage or voltage of the LED also play an important role here.
Also, if you can get a PLUM96(most probably from taobao), you can easily get LEDs from taobao also. They are dirt cheap there.
http://shop34410686.taobao.com/search.htm?spm=2013.1.w6.2.e6ef66&orderType=_hotsell
Offline wetto
  • Brazil's Keyboard Enthusiasts Representative
    • Portuguese Mechanical Keyboard Guide
« Reply #110 on: Sun, 21 October 2012, 09:46:35 »
Does the fact that it does not contains any plate affects it at all? Can someone answer me this?
My collection:
Mice: Logitech G602, CM Storm Recon, CM Storm Spawn, Razer Naga, Ozone Radon Opto, Corsair M60, Tesoro Gandiva, CM Storm Alcor, Mionix Naos 8200.
Keyboards: Matias Secure Pro, Matias Mini Quiet Pro, custom modded Metadot Das Keyboard Model S Professional Silent (MX Brown, Costar), CM Storm Trigger (MX Brown), Noppoo Choc Mini (MX Red), Tesoro Lobera G5NFL Supreme, CM Storm Devastator.
Soon: CM Storm Quick Fire TK (MX Brown), CM Storm Trigger Z.
Boards I don't own anymore: CM Storm Quick Fire Rapid (MX Black), Logitech K800 (Membrane), Logitech G710+ (MX Brown), Thermaltake Meka G-Unit (MX Black), Corsair K70 (MX Red).
Mice I don't own anymore: Logitech G9x MW3, Corsair M65, Logitech G700, Roccat Kone Pure.
Offline Human
« Reply #111 on: Sun, 21 October 2012, 10:01:21 »
What you mean? You mean does the board PCB mounted causing any problems or inferiors? Most(if not all) Cherry made boards are PCB mounted.
Also, as I mentioned, the board itself is solid and heavy.
« Last Edit: Sun, 21 October 2012, 10:03:36 by Human »
Offline wetto
« Reply #112 on: Sun, 21 October 2012, 10:26:29 »
Damn, and here I thought that after gettting my Das Keyboard I wouldn't need to buy any other keyboard in my life.
Well gentlemen, I guess this PLUM 96 will sell quite well here on geekhack, hehehehe.... I'm surely getting mine.
My collection:
Offline Human
« Reply #113 on: Sun, 21 October 2012, 10:37:27 »
The problem is that most China boards are not sold internationally. The most it gone to Taiwan.
You need to find those online vendors such as QTAN to get it but then the price goes up as it passed through more hands and distances.
Offline Cindori
    • My Blog
« Reply #114 on: Sun, 21 October 2012, 14:18:11 »
We have both Lin and Qtan here that acts as Taobao agents, and the fee is not too much.
Offline GensokyoTenshi
« Reply #115 on: Sun, 21 October 2012, 14:33:18 »
Wow, that would really be the perfect layout for me, can't wait to get my hands on one.
Current keyboards I own:
HHKB Pro 2 | Leopold FC500RT/AB (Cherry MX Brown) | Ducky DK-1008 (Green ALPS)
Offline wetto
« Reply #116 on: Sun, 21 October 2012, 14:52:22 »
I think I'll order 10, need to sell some around here in my country....  :p
« Last Edit: Sun, 21 October 2012, 14:59:42 by wetto »
My collection:
Offline nullstring
« Reply #117 on: Wed, 24 October 2012, 20:36:46 »
is plum96 available in mx brown anywhere yet?
Offline desal
« Reply #118 on: Thu, 25 October 2012, 00:25:39 »
There's plenty on taobao. I just got one from qtan yesterday.
Offline nullstring
« Reply #119 on: Thu, 25 October 2012, 01:16:33 »
What was the total cost?
Offline N8N
« Reply #120 on: Thu, 25 October 2012, 06:07:14 »
Do want.
Offline Grimey
« Reply #121 on: Thu, 25 October 2012, 09:46:06 »
Loving my Panda Clears modded PLUM96 myself (work mate modded his PLUM96 to ghetto Light Grays).  It was interesting open up the board and see PCB was LED ready for every switch.  It is a totally decent board all around if you don't mind the Leopold 500 spacebar stabilizer spacing and cherry stabilizers.  The battery life isn't all the great in wireless mode, which is probably why it comes with a on/off toggle switch for it.
Just glad to see some interest peeking for this layout around the globe.
Erlang your pants off
Offline desal
« Reply #122 on: Thu, 25 October 2012, 12:42:28 »
I got some other stuff too and i'm not sure of the breakdown, I think it was about $80-90 shipped.
Offline Human
« Reply #123 on: Fri, 26 October 2012, 13:23:53 »
Wondering what are your complaint on the battery life?
What I read in China forums are that the battery life is actually pretty good.
At least for mine, it is still clearly functioning after a week of usage(on average around 4hours per day). Also, I am not expecting it(the battery) to die out that fast, as it actually using 3x AAA Energizer MAX batteries(which cost around 0.7USD each here and can normally last me a very long time for other uses) + it is awkward to keep on removing the case for changing battery.
« Last Edit: Fri, 26 October 2012, 13:26:45 by Human »
Offline Grimey
« Reply #124 on: Fri, 26 October 2012, 14:28:40 »
As I should probably point out, I have only had 2 attempts at monitoring battery life.  Both attempts provided about 10 days of battery life when wireless mode was left toggled on (the switch left on the wireless on position) while attached wirelessly to our media box which does not shut down.  These tests were not scientific or anything of that nature, but the actual time spent typing is very little.
If these were rechargeable I would not complain in the least at this amount of battery life, but the pain of opening it up and replacing the batteries has kept me very astute to toggle the wireless off when I am not doing any typing.  So the problem basically solves itself by just remembering to toggle the device off, but it would be nice if the device would put itself in standby after 10 minutes of non-use or something.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #125 on: Fri, 26 October 2012, 17:16:57 »
I think that PLUM 96 is my next board. So the consensus is qtan is the way to go?
Offline Grimey
« Reply #126 on: Fri, 26 October 2012, 22:36:37 »
Got mine through IMSTO, but qtan has good rep here as well.
Offline Carter
  • CM Storm Rep
  • * Commercial Vendor
« Reply #127 on: Fri, 26 October 2012, 23:06:57 »
Blue TK's will be available to people very soon. Followed by Red and lastly brown
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #128 on: Fri, 26 October 2012, 23:21:46 »
I'm tempted to get one in brown.  I would have my pennies saved for one if there was a black, though...
Offline wetto
« Reply #129 on: Fri, 26 October 2012, 23:22:06 »
Nice to hear, though, what really made CM not release it in Cherry MX Black? Some gamers even like those.
My collection:
Offline Human
« Reply #130 on: Sat, 27 October 2012, 11:38:58 »
It do had a "standby mode", which turn indicator LEDs off when keyboard is not in used for a durations on wireless mode. You can also manually doing so by Fn+F7.
Also, may be you should try with a better battery and see if the results turns out better.
« Last Edit: Sat, 27 October 2012, 11:43:23 by Human »
Offline Human
« Reply #131 on: Sat, 27 October 2012, 11:40:26 »
BTW, IIRC, PLUM96 may come out with an improved/refreshed version soon. The main different should be an opening at the back to reach the batteries without open up the whole board.
« Last Edit: Sat, 27 October 2012, 11:42:27 by Human »
Offline wetto
« Reply #132 on: Sat, 27 October 2012, 11:42:35 »
Anyone knows where I can buy one of those PLUM 96 keyboards? Someplace where there's international shipping as well.
« Last Edit: Sat, 27 October 2012, 11:44:12 by wetto »
My collection:
Offline Human
« Reply #133 on: Sat, 27 October 2012, 11:44:14 »
Yup, just read back and noticed my mistake. Had edited my previous post.
As above, some ppl said that QTAN is carrying the boards, which mean you can probably get it from him.
Offline Grimey
« Reply #134 on: Sat, 27 October 2012, 23:46:02 »
I wouldn't disagree with anything you said, this keyboard may have somewhat of a standby mode.  My experience has been that actually toggling it off (the switch underneath) when not in use has given me a full month + of usage on the current set of batteries.  When the majority of typing I do is a few quick command line entries and plugging in some URLs it just seemed easier to toggle for now.  I will probably try the standbye mode again at some point in the future, I would rather just not take the keyboard apart every other week to change the batteries.
