Author Topic: I have some yellowed wyse key caps, what do?  (Read 3969 times)
Offline MyNameIsFinn
« on: Sat, 07 April 2012, 09:21:06 »
I tried oxy-clean and hydrogen peroxide, no go..
What should I do? I want the yellow gone right meow.
[SIGPIC][/SIGPIC]
Filco TKL MX Brown
« Reply #1 on: Sun, 08 April 2012, 00:19:13 »
I tried Hydrogen Peroxde and oxy clean, and it worked for me. How long did you soak it? What percentages did you use? I would recommend soaking for 7 days or more, depending on the amount of yellowing to be found.
I would recommend to keep soaking it. Try to get in sunlight if you can, as I have read that some UV radiation will speed the process, though this has not been verified, as far as I have seen.
Offline jellowiggler
« Reply #2 on: Mon, 09 April 2012, 18:25:05 »
The uv component is a must.
If you are using a regular 10 col or 3% solutions you can leave them in for a long time. 8-11 hours. I'd you have a higher concentration you should check every few hours.
Mike -jellowiggler-
Filco MJ2 Tenkeyless / Rosewill RK-9000 / IBM Model M 1391401 / Logitech DiNovo Edge / MS Sidewinder X4
Offline msimon
« Reply #3 on: Wed, 11 April 2012, 08:51:41 »
I have no idea why but i thought the title said.
 I have swallowed wyse key caps, what do?
