Author Topic: Cherry MX keycaps on thingiverse  (Read 7121 times)
Offline rantenki
    • http://armyofevilrobots.com/
« on: Sat, 07 April 2012, 11:07:38 »
Hey all, just thought I would drop a heads up that thingiverse has a keycap library that I am working on. You can take a (very early) peek here:
http://www.thingiverse.com/thing:20953
There will eventually be a full set of parametrically generated keys, I just need to get a script together that actually generates them from a spreadsheet rather than having to manually set the design parameters. It's in solidworks, btw.
Cheers;
 - Derek
p.s. The flash really added a sheen. The key doesn't stand out at all from the other keys (other than being cleaner) in person.
Offline laikaislost
« Reply #1 on: Sat, 07 April 2012, 14:23:58 »
Fantastic!
What are you using to print the key?  Also, since I do not own solidworks, can you tell me what the volume of material (in c^3) needed for the keys?
Offline rantenki
« Reply #2 on: Sat, 07 April 2012, 14:45:52 »
There is nearly no material, maybe a couple meters of filament tops. I am using a PLA plastic in a reprap, specifically this one:
[video=youtube_share;OuQZ-TEaSpg]http://youtu.be/OuQZ-TEaSpg[/video]
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #3 on: Sat, 07 April 2012, 14:59:20 »
Thank you for proving the concept!
Awesome shizzle.
Fight For Freedom. Stand with Hong Kongers
