Author Topic: What happens to my Model M 1391405?  (Read 1607 times)
Offline Delstatenthule
« on: Sun, 08 April 2012, 11:54:52 »
Hello friends, it turns out that for a while when I press the button "M", automatically and simultaneously, the key "," is pressed, which is next ... is hopeless, I don't know it may be :(
One day I open the keyboard and I cleaned the inside, but I did not remove the PCB, just wiped the dust that is above the PCB ... and by magic I solved it and until he has done it again a few days ago.
What happens?
Offline mich
« Reply #1 on: Sun, 08 April 2012, 16:06:18 »
To me it looks like some mechanical problem in the switches. Remove affected keys and check if there is no junk in the barrels, especially under the hammers.
« Reply #2 on: Sun, 08 April 2012, 16:39:29 »
Quote from: mich;570802
How do I remove the PCB to check?
Offline mich
« Reply #3 on: Sun, 08 April 2012, 18:42:48 »
You don't need to open the case, let alone touch the PCB. Keycaps are removable from outside, just lever them with a screwdriver.
Offline rknize
    • metaruss
« Reply #4 on: Mon, 09 April 2012, 14:58:19 »
What happens when you pickup the keyboard and pitch/shake it around?  Do you hear anything clattering around in there?  If you have broken rivets, this could cause weird behavior.  Look down between the rows when you have the keycaps out in the problem area.  See any cracks in the black plastic?
Russ
