Author Topic: Look what I salvaged from work  (Read 1603 times)
Offline Phagocytosis
« on: Sun, 08 April 2012, 12:36:26 »
[ Attachment Invalid Or Does Not Exist ] 47800[/ATTACH]
it's an IBM Wheelwriter 30 Series 2, which is an electronic typewriter.  It uses buckling springs like the other IBM keyboards like the Model M.
It's a real pity that it doesn't turn on but maybe I can still salvage the keycaps if I can't fix it.
Leopold TKL - Ghetto Green
Apple Extended II - Orange Alps
Offline SmallFry
« Reply #1 on: Sun, 08 April 2012, 14:08:35 »
There is a guy here that fixes Wheelwriters... I can't recall his username off hand.
Offline t13
« Reply #2 on: Sun, 08 April 2012, 14:33:08 »
Is it the Wheelwriter that has interchangeable keycaps with the two-piece Model Ms, or is there another model that has that feature?
« Reply #3 on: Sun, 08 April 2012, 14:35:37 »
Quote from: SmallFry;570742
that would be pretty awesome but I am pretty sure shipping would be a pain
Quote from: t13;570755
what exactly do you mean by this? the keycaps come off if that is what you talking about haha
« Reply #4 on: Mon, 09 April 2012, 12:13:22 »
Anyone have any ideas where I could get this fixed or what common problems are for this?
