Author Topic: Ultratec Minicom IV  (Read 2857 times)
Offline Magna224
Ultratec Minicom IV
« on: Sun, 08 April 2012, 19:50:04 »
Look what I found. Its a kind of text messaging system that you hook your phone up to. It was apparently designed for deaf people.
If you live in AZ you can try my keyboards. I usually keep plenty of different ALPS and MX and buckling springs.
Offline IvanIvanovich
  • Mr. Silk Underwear
Ultratec Minicom IV
« Reply #1 on: Mon, 09 April 2012, 09:32:04 »
Sweet. I thought it was Cherry but could never get the seller to confirm it. Just pulled the trigger on one too, I really dig the number row.
Offline sth
  • 2 girls 1 cuprubber
Ultratec Minicom IV
« Reply #2 on: Mon, 09 April 2012, 09:43:34 »
Nice... now get it working with your PC :)
Ultratec Minicom IV
« Reply #3 on: Mon, 09 April 2012, 09:49:19 »
LOL... don't know about OP, but will only be cannibalized by me. $25 is not too bad for some interesting doubleshots though. Would be nice if can used the vfd somehow, vintage blacks are good.
Offline sth
Ultratec Minicom IV
« Reply #4 on: Mon, 09 April 2012, 10:07:47 »
Not having matching mods + punctuation would drive me nuts. What are the key profiles like?
Offline audioave10
Ultratec Minicom IV
« Reply #5 on: Mon, 09 April 2012, 10:09:01 »
Cool...at that price, it should be built like a tank.
DECK Legend "Toxic" - SOLD
96 IBM Model M 82G2383- 95 IBM Model M 92G7453 - SOLD
Cherry G80-3000/Blues
new: MechanicalEagle Z77 RGB/Blues
Offline Magna224
Ultratec Minicom IV
« Reply #6 on: Mon, 09 April 2012, 14:35:45 »
I almost picked up some very odd industrial keyboard thing too. It was a big steel case and had low profile keycaps and a throttle looking thing. It had weird rectangle switches where the spring was horizontal to the pcb and I could see two(maybe one) gold colored stabilizers(?) but it was $12 and I had already blown a lot of money over the weekend. The keycap stem connections popped into holes on the switch housing like space invaders(it was a similar 3 hole stem setup too). When I pressed the keycap the lower half would go down and the upper half would go up slightly like a teeter-totter.
« Last Edit: Mon, 09 April 2012, 14:37:51 by Magna224 »
Offline PRISONER 24601
Ultratec Minicom IV
« Reply #7 on: Tue, 10 April 2012, 03:52:11 »
I have an old TTY machine with cherry blacks too. It's AT&T branded and looks almost identical to yours/
Ever tried. Ever failed. No matter. Try Again. Fail again. Fail better.
G80-3000LSCRC-2 (MX), "Ricercar" G86-6241OEUAGSA (MX), MX11800 (MX), AEKII (ALPS), AEK (ALPS) Apple Keyboard A9M0330 (ALPS), IBM Model F XT (Bucking Spring), IBM Space Saver 1391472 (Bucking Spring).
