Author Topic: Acetone - usable solvent for switches?  (Read 2146 times)
Offline Baneat
« on: Sun, 08 April 2012, 22:08:01 »
I spilled a can of red bull in my green ALPS keyboard, pure water doesn't dissolve the gunk in the switches that make them non-functional. Can acetone be used for this or is it too aggressive to use on electronics? Pure alcohol is very difficult to come by, typically they'll pollute it deliberately for legal reasons. I have pure acetone though, so if that would work then hooray!
Offline eyesnine
« Reply #1 on: Sun, 08 April 2012, 22:18:27 »
99%+ purity Isopropyl alcohol is fairly easy to find, and is used to clean electronics.
Acetone is used as a plastics solvent (wikipedia), so it's probably not a good idea to pour it on a keyboard.
« Last Edit: Sun, 08 April 2012, 22:20:52 by eyesnine »
Offline Magna224
« Reply #2 on: Sun, 08 April 2012, 22:40:29 »
A cat spilled a smoothie on my 1087XM and I used rubbing alcohol and cue tips to clean it.
If you live in AZ you can try my keyboards. I usually keep plenty of different ALPS and MX and buckling springs.
Offline rknize
    • metaruss
« Reply #3 on: Mon, 09 April 2012, 21:48:16 »
Actually, that was a very helpful answer, ripster. :tongue:
To answer your question directly, acetone will happily dissolve ABS.  Probably not what you want.
Russ
Offline 1391401
  • MX CLEAR
« Reply #4 on: Mon, 09 April 2012, 22:03:28 »
Alcohol is polluted a la "denatured" for the purposes of preventing consumption but I have certainly used a rubbing alcohol (Isopropyl) for purposes of cleansing surfaces of a multitude of contaminants sugar inclusive
People I've given money to from this webform who never respond to me and have not shipped me anything: ctrlalt.io 1 2, Team Readline Reputable alternatives to GH group buys: http://pimpmykeyboard.com, https://www.massdrop.com,
