Author Topic: Why do all cherry G80 boards have a clear switch?  (Read 1584 times)
Offline bavman
« on: Wed, 11 April 2012, 22:03:02 »
Every single G80 board I've taken apart to harvest for parts has always contained a 1 clear steam (at least). The blank key above the F12 always contains a clear stem even if all the other stems are brown. Why is this? Does this actually serve a purpose or did cherry do it for the lulz?
Offline Quarzac
  • A very busy dude!
  • Still around, sometimes.
« Reply #1 on: Wed, 11 April 2012, 22:21:56 »
Blank key above F12? The only G80 I have is the 3000, which has a green switch in the space bar. That's the only pseudo-oddity.
Risen from the dead for a model F.
Wyse buy colors were GSY for the dark grey, GBA for the light grey, and BBI for the fonts.
Offline eyesnine
« Reply #2 on: Thu, 12 April 2012, 04:33:30 »
Quote from: bavman;573441
I like to swap the clear stem and spring with the gray spring and stem under the space bar.
I have no idea what the clear stem is for otherwise.
Offline bavman
« Reply #3 on: Thu, 12 April 2012, 09:32:10 »
I guess its only applicable to the 120-key POS board like this: http://www.cherrycorp.com/english/keyboards/POS/8113/index.htm
Offline keyboardlover
« Reply #4 on: Thu, 12 April 2012, 12:53:15 »
Are you familiar with Cherry's product code schema?
I'm going to go with "for the lulz".
