Author Topic: How to change my win7 keyboard layout to dvorak  (Read 1829 times)
Offline twilek
« on: Thu, 12 April 2012, 11:37:08 »
Hi, you see I'm really new to keyboards and as you would guess I'm very used to the qwerty layout. It would be nice if I were layout "bilingual" but either way it would be excellent if someone could tell me how to transfer my qwerty layout to the dvorak layout. Also I would be much obliged if someone also told me how to do this system wide. I currently run ubuntu so it's easier to change to dvorak like that. Also if someone could tell me a program or website where I could learn how to type in dvorak that would be great.
Offline boli
« Reply #2 on: Thu, 12 April 2012, 12:35:46 »
While you're at it you might want to consider the Colemak keyboard layout instead.
I also almost switched to Dvorak, then I found out about Colemak and switched to that instead.
You'll find lots of information on that site, and also in this very subforum.
Keyboard: Kinesis Ergo Advantage (two LF editions with red Cherry switches, one regular with brown switches)
Keyboard layout: basically Colemak, with some remapping to end up with my custom Kinesis Advantage layout
Typing test profiles: typeracer.com / hi-games.net / keybr.com
Offline Playtrumpet
« Reply #3 on: Fri, 13 April 2012, 08:21:46 »
http://gigliwood.com/abcd/lessons/
Gives a good introduction to the layout and after finishing the lessons your fingers will have the layout memorized.
Dvorak
« Reply #4 on: Tue, 17 April 2012, 20:23:40 »
I almost switched to colemak, but decided, I preferred Dvorak's philosophy more. At the moment, though, my windows keyboard is in QWERTY, as it only gets used for gaming and typing URLs.
Make a note of the key combination you use to switch between layouts, as it was very useful to me when I learned.
Playtrumpet: That's the second time I've seen the A Basic Course in Dvorak posted, I'll have to check it out again.
