Author Topic: where to buy blank brown caps for filco?  (Read 4497 times)
Offline FinancialWar
« on: Sun, 15 April 2012, 21:07:17 »
hello, I am getting the Camo edition of filco 104, I saw pictures of this board with blank brown caps and it look great (can't find the thread though). I wonder where can I get this particular keycaps?
Offline reaper
« Reply #1 on: Sun, 15 April 2012, 21:52:57 »
Brown?  Have you tried WASD Keyboard?  They do custom keycaps there...  unless you have some pictures of these brown keycaps you mentioned. =P
Din Eli
Offline harrison
« Reply #2 on: Sun, 15 April 2012, 21:56:26 »
I've not seen brown, in either ABS or PBT new... i know there was a coffee and cream SP set talked about a while back, not sure if it went anywhere.  i've seen some old school double shots in brown, but that's about it.
[work]ducky tiger dk-9008G2, cherry mx brown|logitech performance mx
[home]corsair k70 LUX RGB, cherry mx brown|logitech G700s
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3 on: Sun, 15 April 2012, 22:06:22 »
Asides from dying PBT brown, I have no idea... I have 2 sets of Cherry doubleshots in brown shades. One is from a Commodore branded Cherry G80-499 which are tan/dark beige with black legend, the other was from some mystery board which were coffee on cream.
If you aren't keen on dying you might have a look for some of those Cherry.
« Reply #4 on: Tue, 17 April 2012, 19:54:58 »
There are lot of exciting PBT colours that WASD is releasing soon, though I didn't see Brown among them. Perhaps if there is enough interest, he will be able to add them to the colour options, as it's still "tentative".
http://geekhack.org/showthread.php?29995-PBT-Pricing&p=573327&viewfull=1#post573327
Other than that, the best bet would be doing a custom order via SP, or dying them.
Offline harrison
« Reply #5 on: Tue, 17 April 2012, 20:23:18 »
Quote from: dorkvader;577482
it would appear (although with thin not thick PBT) that qtan is going to offer custom PBT dying.  That might be one route.  Check this thread out: http://geekhack.org/showthread.php?30346-Now-coming-104-custom-caps-set.  My assumption is that since they're going to offer any color other than black, they'll start with a white key, laser it, and then dye it.
