Author Topic: 104 PBT set for Leopold FC500R  (Read 5282 times)
Offline mr626
« on: Tue, 17 April 2012, 04:53:04 »
Hi all,
As mentioned in another thread, I'm starting to notice some serious shine on the ABS keys of my FC500R. So, I'd like to buy a set of PBT for my board.
I was looking at getting these:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=330704484534&ssPageName=ADME:X:RTQ:US:1123#ht_500wt_1413
But when I sent a message to the seller to confirm compatibility he said that the spacebar won't fit.
Can anyone point me in the direction of a PBT keycap set that will suit my board, including the spacebar?
Thanks
« Reply #1 on: Tue, 17 April 2012, 09:00:21 »
Spacebars can be modded to fit the Leopold.
I have considered doing it myself, Dremels, jigs, and epoxy are required, if you enjoy tinkering with things.
Somebody here in the forum will do it for a reasonable sum, either on your spacebar or one he supplies.
Test the improved "search" function and see if it turns up!
- D Trump 2026-10-24
Offline mr626
« Reply #2 on: Tue, 17 April 2012, 17:02:06 »
Thanks for the suggestion. It's just annoying that Leopold decided they had to be different with their spacebar!
Offline Grimey
« Reply #3 on: Tue, 17 April 2012, 17:41:22 »
I have this myself.  It required a set of PBT caps and getting someone to modify it.  The space bar on the 500r is just different enough to make sure it won't fit with a 200r space bar.  The Profist(spelling I am lazy now?) has a jig to make this happen if you contact him.
Erlang your pants off
