Author Topic: Mr Clean Magic Eraser  (Read 6367 times)
Offline lROOl
« on: Wed, 18 April 2012, 16:35:50 »
I am sure this has been brought up before but just in case it hasn't Mr Clean Magic Eraser is amazing for cleaning dirty key caps. I had a couple of white keys that had some kinda scuff on them, I tried Oxy Clean 3 times and it worked a lot but still didn't get them fully clean. I just randomly tried the Magic Eraser and in 1 sec the key looked brand new
« Reply #1 on: Wed, 18 April 2012, 16:42:24 »
Those are good products, but, in spite of how they feel to the finger, they ARE abrasive.
I have put a couple of shiny spots on keyboard cases, which were still better than the black marks that were removed, but be careful.
I recommend trying a regular white vinyl pencil eraser, like a "Magic Rub" first, and hold the Mr Clean product back as a last resort.
- D Trump 2026-10-24
Offline lROOl
« Reply #2 on: Wed, 18 April 2012, 16:45:22 »
Quote from: fohat.digs;578262
good advice, I dont know what was on these keys but i tried for like 2 days to get them clean and the only thing that worked was the magic eraser
« Reply #3 on: Wed, 18 April 2012, 16:52:56 »
My usual process is soap and water first, then alcohol, then something like Windex, finishing with something like bleach.
Moving past water-based solvents, and being very careful, I try organic solvents (citrus oil), then naptha (old-fashioned lighter fluid), then acetone.
If none of those dissolve the gunk so that I can wipe it off, I start in with abrasives, beginning with pencil erasers.
I have only found a couple of keys that were actually stained at a penetrating level, where nothing worked to remove the blotch.
Cases are more likely to have really stubborn problems, in my experience.
Offline lROOl
« Reply #4 on: Wed, 18 April 2012, 17:02:24 »
Quote from: fohat.digs;578273
aw ok see I didn't know if using bleach would hurt the keys good to know thank you
« Reply #5 on: Wed, 18 April 2012, 17:38:05 »
Bleach won't hurt them but the oil-based and organic solvents could.
I don't think I have ever hurt a PBT cap, but I have certainly wrecked ABS ones by various techniques.
