Author Topic: Modify / reuse Apple aluminum?  (Read 1347 times)
Offline Netdewt
  • OLKB
« on: Thu, 19 April 2012, 09:23:21 »
I have a dying Apple aluminum at home that drops new keys every day. Any ideas on how I could reuse the case? Crazy thought... but what if I added thickness to it and soldered in Cherry switches? I suppose all the key sizes are wacky.
Offline sth
  • 2 girls 1 cuprubber
« Reply #1 on: Thu, 19 April 2012, 09:26:52 »
Could be a cool project but the PCB won't be at all compatible with cherry switches.
You could probably find a schematic for it online and create a cherry version relatively easily though.
Offline urbanus
« Reply #2 on: Thu, 19 April 2012, 09:43:33 »
Quote from: Netdewt;578778
It might help if you posted your exact model.  However if it's anything like the Apple aluminium keyboards I've used I think it would be challenging, especially on the top and bottom rows.  Apple function keys are small and down close to the number row.  On the bottom, their ctrl, alt, meta and space bar sizes and positions might not match the keys you're cannibalising... unless, that is, you're planning to mount the Apple scissor-switch keycaps on top of the new cherry switches.  It would be tricky to get that working smoothly.  And what about stabilisers on the larger keys -- where would they mount?
I think this would be quite a tricky mod.  If you could get it all working that would be insane... maybe in a good way, but not necessarily. :smile:
Offline Netdewt
  • OLKB
« Reply #3 on: Thu, 19 April 2012, 09:49:19 »
Are there different models?
[ Attachment Invalid Or Does Not Exist ] 48600[/ATTACH]
Not likely I can do this, I just have a trash keyboard... maybe worth a try.
