Author Topic: whats the KRO on these Cherry boards?  (Read 1522 times)
Offline bazemk1979
« on: Fri, 20 April 2012, 00:40:19 »
CHERRY G80-8200
CHERRY G80-8113
Any info would be appreciated
fossala
  •  Guest
« Reply #1 on: Fri, 20 April 2012, 01:55:56 »
2KRO AFAIK
Offline bazemk1979
« Reply #2 on: Fri, 20 April 2012, 02:21:56 »
so even with PS/2 plugged in they are at 2KRO.... you know which combo fails around WASD, as a gamer I only found I need 3 buttons to be pressed at the same time from time to time, you know which combos fail around WASD areas?
fossala
  •  Guest
« Reply #3 on: Fri, 20 April 2012, 02:23:48 »
No I wouldn't know, but they won't be optimized around the wasd cluster as it is a pos keyboard not a gaming one. There are only a handful of cherry keyboards that do have NKRO.
