Author Topic: Canon EOS 600D Vs Nikon D5100 Vs Nikon D7000 Which one worth to buy it?  (Read 3993 times)
Offline net2522
  • lollollollol
Which one worth to buy it? for long term use.
Thank you in advance
Offline harrison
« Reply #1 on: Mon, 23 April 2012, 12:42:01 »
http://www.dpreview.com/products/compare/side-by-side?products=canon_eos600d&products=nikon_d5100&products=nikon_d7000
well, i'm a bit of a canon fanboy myself, but the d7000 isn't a fair/direct comparison to the other two.  the 600d and d5100 are going to come down to a brand preference, they really are similar cameras other than the sensor and firmware.  for the price, both are excellent cameras.
if the cost isn't an issue though, and the d7000 or canon 7d are going to be significantly better cameras for the longevity.
« Last Edit: Mon, 23 April 2012, 12:44:56 by harrison »
[work]ducky tiger dk-9008G2, cherry mx brown|logitech performance mx
[home]corsair k70 LUX RGB, cherry mx brown|logitech G700s
Offline net2522
  • lollollollol
« Reply #2 on: Mon, 23 April 2012, 12:46:21 »
^ thanks for the information
is it effective pixels do they effect the picture quality.
canon 18.0 megapixels both of nikon 16.2 megapixels.
Thanks
Offline laffindude
« Reply #3 on: Mon, 23 April 2012, 18:13:59 »
Unless you're going to print huge sizes, pixel means little to nothing. Unless you're doing landscape, in which case, you're looking at the wrong cameras.
I'd buy the D7000 out of those listed, simply for using older Nikkor D lenses. Screw longevity, buy the best lenses you can afford and buy a cheap camera. Expensive camera won't be better than entry level camera 2 years from now.
