Author Topic: MechanicalKeyboards.com --- Switch Ranker [beta] now LIVE!  (Read 16658 times)
Offline ShakeR
  • * Moderator
    • http://mechanicalkeyboards.com
« on: Mon, 23 April 2012, 21:17:13 »
The Switch Ranker is officially up!
We need YOUR input to get the most accurate information possible for determining which switches are best for what.
Check it out!
http://mechanicalkeyboards.com/mechanical_switches.php
edit: I'm using the word 'beta' in case there are some bugs we aren't currently aware of with the form.  If you run into any, please let us know! support@mechanicalkeyboards.com
MechanicalKeyboards.com - What do you type on?
Offline thegunner100
  • (╯'□')╯︵</3 ノ( '-'ノ)
    • The Emotional Skyscraper
« Reply #1 on: Mon, 23 April 2012, 21:40:52 »
While you're at it... vote for your favorite switch here! Sorry if this is considered thread jacking :P
I did vote for whatever i've used before though.
Input Devices:CM QF Rapidx2 ~ REALFORCE 87uw 45/55g ~ Logitech G5v2 ~ Wacom Bamboo CTH-460
Audio Setup: look me up on head-fi
Check out my blog on touhou/doujin music, audiophile gear, and doujin games!
Offline AKIMbO
  • HHKBro
« Reply #2 on: Mon, 23 April 2012, 22:03:31 »
Voted for all the cherry switches and buckling springs (the only switches I've used).  You should elaborate what "balance" means.
| KBD75 (box reds)
« Reply #3 on: Mon, 23 April 2012, 23:46:42 »
I notice that IBM currently ranks highest for typing.
I'm really enjoying the website! Also TN -> VA (where I live) is a short distance :)
Offline ShakeR
  • * Moderator
« Reply #4 on: Tue, 24 April 2012, 11:59:12 »
Quote from: AKIMbO;580499
Yeah, it's a always a battle between simple design and sufficient information.  The title header kind of explains it and if you hover your mouse over the balance icon it helps as well.  Thanks for the feedback - this is a common one so far.
Yeah, I need to see about picking one up as it's really sparking my interest.  I'm more of a new-schooler and haven't typed on a Model M in the last 20 years.
Come by and see us! :)
« Reply #5 on: Wed, 25 April 2012, 00:04:52 »
Quote from: ShakeR;580890
I only own a bicycle: no car or I would, and bring my Unicomp with me.
Have you tried contacting unicomp about distributing their keyboards for them?
Good to see some Topre ratings starting to trickle in.
Offline ShakeR
  • * Moderator
« Reply #6 on: Wed, 25 April 2012, 10:41:22 »
Quote from: dorkvader;581465
I was looking at their site yesterday.  Will probably be contacting them soon.
