Author Topic: Questions for People with KBC Pokers!  (Read 2472 times)
Offline yearn4
  • formerly known as 4en
« on: Thu, 26 April 2012, 12:50:45 »
Can you tell me how many keys are in each row like R4 = ESC, F-row, number row stuff like that = 20(made up number)
i wanna order a bunch of novelty keycaps to finish my entire poker that i will be receivng next month
Offline Nighted
« Reply #1 on: Thu, 26 April 2012, 12:52:13 »
There are plenty of photos of Pokers on the forum.
^ 100% teleprompter free.
[SIGPIC][/SIGPIC]
Offline nanobadger
« Reply #2 on: Thu, 26 April 2012, 13:32:40 »
Quote from: 4en;582892
I will say the search on here gives too many results, even with quotes, &, etc.
Look on eBay, KBC keycaps on there.
Also, youtube KBC poker and you can get a feel for the keys and functions.
Offline sth
  • 2 girls 1 cuprubber
« Reply #3 on: Thu, 26 April 2012, 15:48:50 »
14 (13 1x)
14 (12 1x)
13 (11 1x)
12 (10 1x)
8
The poker layout is the same as the homerow block on a standard 104 key.
Offline yearn4
« Reply #4 on: Thu, 26 April 2012, 15:54:50 »
Quote from: sth;583057
14 (13 1x)
14 (12 1x)
13 (11 1x)
12 (10 1x)
8
Thank you for your helpful post do you know if they follow the row sizing format as regular keyboards for exanple in filco and leopold the esc, f1-12 and  ~ to 0 are all row 4 sizing
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #5 on: Thu, 26 April 2012, 15:58:12 »
Yes. It is identical, same profiles, sizes etc. It's 100% standard.
Offline sth
« Reply #6 on: Thu, 26 April 2012, 17:48:58 »
Yeah, assuming you're referring to ANSI layout.
Offline yearn4
« Reply #7 on: Thu, 26 April 2012, 20:50:03 »
Ty you 2 ^_^
