Author Topic: PBT Keycaps with ISO layout  (Read 7158 times)
Offline HoBbe
« on: Fri, 27 April 2012, 07:54:34 »
Hello!
I recently bought a Filco MJ2 and the keys i use for starcraft 2 the most are starting to wear out
Note V and D (pic is around 10 days old so they look even worse now+z,c,r.)
So i'm looking for 105 ISO PBT keyset. Best would be blank black or white keyset, but it really doesn't matter.
I've been looking around quite a bit but haven't found any, help!
Offline Djuzuh
« Reply #1 on: Fri, 27 April 2012, 07:55:59 »
Nobody seems to have found any, but wasd has said they'll get PBT in june so maybe we'll be able to get an iso set from them.
« Reply #2 on: Fri, 27 April 2012, 08:31:24 »
There's been a lot of interest in ISO PBT recently.
If you're wearing out your keycaps that fast, you might want to get an ANSI PBT set, and live with the different keys for now. I am hoping WASDkeyboards will have ISO PBT in a few months, so then you can replace them properly.
Offline HoBbe
« Reply #3 on: Fri, 27 April 2012, 09:00:00 »
I might have to buy in ANSI layout and hope WASDkeyboards will get PBT in ISO.
Whats the best site to buy brand new pbt keycaps?
Offline Djuzuh
« Reply #4 on: Fri, 27 April 2012, 09:10:12 »
Look out in the group buy section, there are 1 or two running afaik
Offline Gothic860
« Reply #5 on: Thu, 03 May 2012, 01:42:53 »
Yup + you can get a lot of different Keycapsets from GBs :). I have recently changed and Im happy.
« Last Edit: Thu, 03 May 2012, 01:44:59 by Gothic860 »
Offline zirb
« Reply #6 on: Thu, 03 May 2012, 07:23:53 »
Quote from: dorkvader;583823
the hope is strong in me, too :)
« Reply #7 on: Thu, 03 May 2012, 08:20:20 »
Y'know, I just relized: Cherry should have PBT ISO enter keys. I believe they have Lasered (and sometimes dyesub) PBT keys. You could grab a UK or German 'board and have a full keyset right there.
