Author Topic: Wanted: NEW Genuine Cherry PBT spacebar in Filco size x2  (Read 2153 times)
Offline shawn o
  • Trade Count: (0)
« on: Fri, 27 April 2012, 16:45:31 »
Filco size spacebar is 6.0 units right? Or 5.75?
Anyways I need one or even two would be better. Want to mod them to fit a Filco (or two if I get em right).
Offline Reptile
  • Trade Count: (0)
« Reply #1 on: Fri, 27 April 2012, 16:51:38 »
I got a black one. Filco size but off center and brand new
sent from my mobile
Home:Realforce 87UB 55g
Work:Leopold FC700R Ergo Clears
Offline IvanIvanovich
  • Mr. Silk Underwear
  • Trade Count: (0)
« Reply #2 on: Fri, 27 April 2012, 16:54:51 »
You need 6.25... So you need white/beige one if you're looking for PBT? Black is ABS or POM only.
Offline Reptile
  • Trade Count: (0)
« Reply #3 on: Fri, 27 April 2012, 17:17:13 »
Quote from: lysol;584206
The ones that say pbt are still abs?
sent from my mobile
  • Trade Count: (0)
« Reply #4 on: Fri, 27 April 2012, 17:22:11 »
Yes. They used the same mold for all their 6.25 and 6 space bar, regardless of the material. They all say PBT, but only the ones that have a '3' etched in are PBT which only come with the white all PBT set, 2 are abs and 1 are POM. As far as I can tell all of the larger old style are ABS only as all of the ones I have come across all have a '2'.
« Last Edit: Fri, 27 April 2012, 17:27:14 by lysol »
Offline Reptile
  • Trade Count: (0)
« Reply #5 on: Fri, 27 April 2012, 17:24:35 »
Quote from: lysol;584233
Yes. They used the same mold for all their space bar, regardless of the material. They all say PBT, but only the ones that have a '3' etched in are PBT, 1 are abs and 2 are POM.
K cool thanks. Shawn pm me if you want a new abs black one
sent from my mobile
Offline shawn o
  • Trade Count: (0)
« Reply #6 on: Fri, 27 April 2012, 23:50:11 »
Yep, one I have says PBT so I assumed it was that. PMing you now!
Offline shawn o
  • Trade Count: (0)
Re: Wanted: NEW Genuine Cherry PBT spacebar in Filco size x2
« Reply #7 on: Sat, 11 August 2012, 18:35:58 »
Bump, still looking for a white cherry one!
