Author Topic: ABS Kforce Keycaps  (Read 3545 times)
Offline flizz
ABS Kforce Keycaps
« on: Sat, 28 April 2012, 03:43:03 »
Hi I've been trying to find these specific keycaps for a while now but no luck.
http://www.aliexpress.com/fm-store/803343/210733765-425657195/Purple-Color-37-Pcs-Colorful-Keycap-replaceable-keycaps-for-Mechanical-Keyboard.html
I want this lavender color but I also want the font printed on the key caps similar to how the filco one looks as well.
Does anyone know where I can purchase these key caps?
ABS Kforce Keycaps
« Reply #1 on: Sun, 29 April 2012, 00:32:16 »
Do you mean you want front-printed keycaps (like no the filco ninja), keycaps printed in firco's font (futura, If I recall correctly), or keycaps that are printed then clear coated in the method that filco uses.
I imagine the first may be available now, but the latter two options might not ever come to existence.
