Author Topic: Adesso compact mechanical keyboard - Windows keys alternatives?  (Read 1632 times)
Offline Pixel_Outlaw
So I just bought a new Adesso compact keyboard because it was an affordable option to try Cherry MX Blue keys.
It is not a bad keyboard but I really want to get rid of the windows keys. I don't use windows (Linux instead).
I'm not sure if they are standard Cherry key caps. I believe the keys on my Cherry point of sale keyboard are a bit shorter.
It would be neat to get some blanks or interesting key caps for this model.
Some of the Linux programs I use make use of the Windows key so I really want something without the Windows logo on it.
Here is the model I have:
http://www.adesso.com/en/home/keyboards/mechanical-keyboard/306-mkb-125b.html
It sure is a switch (no pun intended) to move from my full sized IBM terminal keyboard to this...
My fingers now go tick instead of clunk-ping. I like em both.
Brown and black are the colors of cowardice. May my springs shake the heavens!
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #1 on: Sat, 28 April 2012, 14:53:38 »
Pretty sure those are standard KBC / Filco / etc profile caps on Adesso, so order some blanks or custom engraved / lasered keys from wasd.
« Reply #2 on: Sat, 28 April 2012, 15:23:05 »
OK, before I do here is a profile view.
I find it odd that they use single space Windows keys.
I assume it is a "row 1" key. I just want to make sure before I spend a chunk of money on 2 keys.
[ Attachment Invalid Or Does Not Exist ] 49415[/ATTACH]
« Reply #3 on: Sat, 28 April 2012, 18:31:35 »
Yeah, that's right. 1x windows and 1.5 ctrl, alt is what iOne always does.
