Author Topic: Where to find keycaps compatible with Kinesis Advantage  (Read 4333 times)
Offline shockwave
« on: Sun, 29 April 2012, 14:30:19 »
Where can I buy keycaps that are compatible with my Kinesis Advantage? The keycaps on my Advantage are fine (they're actually brand new). I would like like to find some that are different looking, for the hell of it.
Of most importance to me is not to change the size of the keys, since I want the sizes to stay just how they are.
EOT
Offline Human
« Reply #1 on: Sun, 29 April 2012, 16:51:32 »
Quote from: shockwave;585713
EOT
Try some spherical or flat(uni profile) DS from SP/Devlin?
« Reply #2 on: Mon, 30 April 2012, 03:02:09 »
Might I direct you to thi following topic:
http://geekhack.org/showthread.php?23446-kinesis-advantage-keycap-replacement-limitations
In it, some awesome GH'ers have found the exact profiles of all the Kinesis keycaps, and some have successfully found suitable replacements for most of them from WASDkeyboards.
The largest issue is that four of the keycaps near the thumb cluster are the super-tall row5 ones. This issue has been approached in several ways.
Here is a helpful post compiled by boli:
http://geekhack.org/showthread.php?23446-kinesis-advantage-keycap-replacement-limitations&p=507346&viewfull=1#post507346
Offline Input Nirvana
Re: Where to find keycaps compatible with Kinesis Advantage
« Reply #3 on: Sat, 28 July 2012, 00:28:09 »
I'm doing a follow up if anyone has any additional info on Kinesis keycaps..like for key caps in PBT or----?
