Author Topic: Poker DIY kit - EXCLUSIVELY AVAILABLE AT GEEKHACK ! ! !  (Read 105786 times)
Offline metafour
« Reply #100 on: Tue, 01 May 2012, 06:52:58 »
Is this a one time only deal? Has there been talk of doing this for the Pure as well?
I'm really intrigued by this but the timing couldn't be worse for me.  =/
Offline alaricljs
  • I be WOT'ing all day...
« Reply #101 on: Tue, 01 May 2012, 07:28:07 »
Just a note, while you may be able to source Cherry stabilizers elsewhere (like Mouser) you will NOT source them at a price this low.  Make sure you don't forget to order the stabilizers w/ your kit :)
Filco w/ Imsto thick PBT
Offline Wibox
« Reply #102 on: Tue, 01 May 2012, 08:41:46 »
Is it possible to only buy addons, not the kit itself? I am only interested in buying a few plates..
!! YKBDS !! - KBC Poker (Ergo Clear Cherry) - Apple M0116 (Pink ALPS) - Apple M0115 (Orange ALPS) - Das Keyboard (Blue Cherry) - IBM Model F - IBM Model M - Dell AT101W (White ALPS) - Cherry POS 8000 (Clear Cherry) - Apple Extended II (Cream ALPS)
« Reply #103 on: Tue, 01 May 2012, 09:05:05 »
Plate mount eh?
Now im interested
Offline tsangan
  • 1000/600
« Reply #104 on: Tue, 01 May 2012, 10:49:07 »
So for exisiting pokers out there, how is the plate kit going to work? Do we have to desolder everything?
Quote from: WRXChris;587103
No, the board is only wired for the 7 switches that come with LEDs from the factory.  You would have to wire up your LEDs separately, and I have no idea what that circuit would look like other than a rat's nest under your PCB. :(
Like this? Haha
http://www.otd.kr/bbs/board.php?bo_table=album&wr_id=116783&page=2
« Last Edit: Tue, 01 May 2012, 10:59:32 by tsangan »
Keyboardless
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #105 on: Tue, 01 May 2012, 11:07:31 »
Quote from: tsangan;587303
almost certainly. desolder the pcb mount switches, put plate mounts on with the plate. note that the place doesn't have the nice phantom quick swap holes too, so no more switch swapping without desoldering.
Like this? Haha
lol that's lowpoly levels of dedication
Offline tsangan
  • 1000/600
« Reply #106 on: Tue, 01 May 2012, 11:09:17 »
Quote from: mkawa;587312
Ishtob made a plate for this DOX which is basically the same thing as the poker and it was PCB mounted but he added a plate on top afterwards without needing to desolder switches to switch to plate mounted ones, it might have been the plate design I'm not sure.
Keyboardless
Offline balanar
« Reply #107 on: Tue, 01 May 2012, 11:09:41 »
Like this? Haha
They really are light years ahead when it comes to keyboard stuff aren't they?
Offline whiskerBox
« Reply #108 on: Tue, 01 May 2012, 11:14:44 »
Can we just order the plate?
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
Offline mkawa
« Reply #109 on: Tue, 01 May 2012, 11:20:13 »
Quote from: tsangan;587316
1) looking at the dox kb's OP, i don't think the switches on his board are pcb mount -- i don't see holes for the fixation pins on his board.
2) regardless, it looks like the plate retainer piece is on the removable top half of the switch, so i think you're right! we should be able to desolder the existing LEDs, pop all the switch tops off put the plate on, and ta-da. cool!
of course, one still needs to desolder to swap springs/stems once the plates are on, but that is very cool.
still looking for more pcbs...
Offline tsangan
  • 1000/600
« Reply #110 on: Tue, 01 May 2012, 11:28:41 »
We're going to need confirmation on this before we can move forward
Keyboardless
Offline mkawa
« Reply #111 on: Tue, 01 May 2012, 11:33:46 »
Quote from: tsangan;587325
i am always moving forward (lol)
« Reply #112 on: Tue, 01 May 2012, 11:38:56 »
You can use pcb mounted switches with the plate since the pcb has the extra holes for the two extra feet the switch has.
Offline rtos
« Reply #113 on: Tue, 01 May 2012, 11:40:38 »
Is it possible to get a standard plastic Poker case as well?  (Since the kit comes with two PCBs, I'd probably want to build two Poker keyboards, one with an aluminum case and one with a plastic case for portable use.)
Offline WRXChris
« Reply #114 on: Tue, 01 May 2012, 12:59:10 »
Like this? Haha
Ahh, yes, lol.  That doesn't look as bad as I expected; I didn't think about wiring them up in parallel but that definitely makes more sense than series, lol.
Offline mkawa
« Reply #115 on: Tue, 01 May 2012, 13:08:44 »
Quote from: rtos;587334
i will happily sell you a couple plastic poker cases
Offline keebler64
« Reply #116 on: Tue, 01 May 2012, 13:20:10 »
Quote from: ripster;587326
Impressive - I've never seen spaghetti wire SMT!
(Attachment Link) 49626[/ATTACH]
Heh, I deadbug-wire/solder SMD all the time..
Here's my FraggleRock MIDI Door Chime Relay for a '95 VW Golf running on a 32 TQFP SMD ATMEG168...
http://www.youtube.com/watch?v=UWV3cYsR8Wc
Better example of the wires... it was a prototype... very ugly, but performed it's task.  The "white stuff" is hot melt glue.
http://www.youtube.com/watch?v=Lqf9Rgwhoaw&feature=channel&list=UL
Anyway, if anyone needs these boards soldered, I'll offer services of $5 per board, you supply the parts and shipping both ways. I can do a board in 10 minutes or less. I have an oven and hot air system. I can do a 1 day turn-around.
PM me if you're interested. I accept paypal or moneyorders.
Offline mkawa
« Reply #117 on: Tue, 01 May 2012, 13:33:49 »
seriously? hell, that's cheaper than doing it myself
« Reply #118 on: Tue, 01 May 2012, 13:45:16 »
Man that makes that guy wanting 140 look like a real jerk hahaha
Offline keebler64
« Reply #119 on: Tue, 01 May 2012, 13:50:21 »
Yes. I solder/repair IBM Servers/Motherboards every day, as well as build random things in my spare time. I've got a Hakko FX888, Aoyue 852+ Hotair Setup, warming plate, and a basic oven for low-level reflow jobs. I should be able to do BGA reballing soon as well (Xbox360 Repairs).
Normally we charge $75 - $125 an hour, but that's our commercial rates. I'm doing this as a favor to the GH Community.
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #120 on: Tue, 01 May 2012, 13:52:00 »
Quote from: keebler64;587457
You sir are awesome. :thumb:
« Reply #121 on: Tue, 01 May 2012, 13:56:53 »
You're a good guy!
I want to learn how to solder! Any tips?
Offline tsangan
  • 1000/600
« Reply #122 on: Tue, 01 May 2012, 14:00:36 »
Quote from: demik;587464
You're a good guy!
Don't learn from me :thumb:
Keyboardless
Offline keebler64
« Reply #123 on: Tue, 01 May 2012, 14:12:00 »
You're a good guy!
For learning purposes, get some cheap LEDs, a few Caps, some 470ohm resistors, a 3.3v Power source (2-AA batteries) and a $7 Soldering iron from Radio Shack. Pay attention to your tips (soldering iron tips). Do not let them burn, clean them before each solder application, tin them correctly, and do not apply too much heat to the component.
For more advanced stuff. Spend the $60 and get a cheap used Weller or Elenco, adjustable Temp, get a medium-fine tip, and keep it at, or around 400c for most soldering applications. DO NOT use that cheap POS Radioshack on any heat sensitive components. The 25w Irons don't heat the contacts quick enough for the solder to flow properly, which will/can cause damage to the pads and components. De-lamination can occur, as well as total component failure.
Make good use of Flux as well. And keep your contacts clean.
« Last Edit: Tue, 01 May 2012, 14:50:14 by keebler64 »
Offline keebler64
« Reply #124 on: Tue, 01 May 2012, 14:14:35 »
Quote from: keebler64;587478
For learning purposes, get some cheap LEDs, a few Caps, and a $7 Soldering iron from Radio Shack. Pay attention to your tips (soldering iron tips). Do not let them burn, clean them before each solder application, tin them correctly, and do not apply too much heat to the component.
Also, read up on Digital Circuits. Look at their operation, and understand the fundamentals of how an electronic circuit works. Know the difference between an open, short, or crossed/short. Know the difference between A/C and DC current/voltages, and understand the min and max tolerances of the components you are working on.
EDIT: This is WAY off topic guys... need more people to get these Pokers!  /mecrackswhip...
Offline rknize
    • metaruss
« Reply #125 on: Tue, 01 May 2012, 15:05:26 »
Since the plate is just floating and doesn't seem to interface with the PCB or case at all, does it really help all that much?  I suppose it would help with the annoying PCB flex that the poker has.
For folks talking about LEDs, you need to consider ohms law when you calculate what value resistors to use.   The keyboard in that picture appears to be strapping the LEDs to the 5V Vbus.  So for a 2.8V @ 20mA LED, you could calculate the resistor for each LED value as follows:
Vdrop = Vbus - Vled
Vdrop = 5V - 2.8V
Vdrop = 2.2V
R = Vdrop / Iled
R = 2.2V / 0.020A
R = 110 ohms
The closest common value would be a 120 ohm resistor.  That assumes you want them at full brightness.  :)  In fact, you won't be able to light a full set of LEDs at 20mA, due to the supply current limitations of USB (20mA * 80 = 1.6A!).  You'd probably want to run them much lower than this to be safe.  If you use an LED that operates at a voltage lower than 2.5V, you can place them in series pairs.  Then your current requirements drop by half.
Any 1/4W or 1/8W resistor will be adequate.  I wouldn't use SMDs unless you are experienced at soldering.  Regular, axial carbon film resistors will work just fine.
Russ
Offline CuteVoodooDoll
« Reply #126 on: Tue, 01 May 2012, 15:19:07 »
Quote from: keebler64;587426
This guy is going to be either one of the kindest members, or the one with the most poker keyboards XD.
Offline keebler64
« Reply #127 on: Tue, 01 May 2012, 15:27:29 »
Quote from: rknize;587514
Vdrop = Vbus - Vled
Vdrop = 5V - 2.8V
Vdrop = 2.2V
R = Vdrop / Iled
R = 2.2V / 0.020A
R = 110 ohms
Finally someone else that understands!
I was trying to explain to someone that the USB BUS can only support a "max" of 500mA at best, there are plenty of 1.8v LEDs on the market that operate at anywhere between 5mA-10mA, however, they're not nearly as bright as your standard 3.3v. SMD isn't all that bad if you can get comfortable with 30ga wire and have a steady hand. 1206 SMD LEDs are pretty easy to work with (with practice). If you're willing to add a secondary USB Supply, you could run the LEDs at about 10mA safely.
Offline keebler64
« Reply #128 on: Tue, 01 May 2012, 15:37:06 »
I am not looking to make a profit off of this, nor am I asking for boards/pcb's for reciprocation. I'm doing these on my lunch breaks, the $5 covers the time spent not eating.
Now, I wouldn't be apposed to a donation. But I'm not asking for one. If you feel you can not solder well enough to do this job, I have no problem helping out.
If you do consider my offer, I strongly suggest UPS, and please include a pre-paid return shipping label. UPS delivers 3 times a day, and picks up packages at 1700CST. IF the boards are received by 1200cst, I will ship them the same day. If you're in Texas, Oklahoma, and parts of Louisiana, it will be next day via Ground w/ UPS.
PM for additional details.
EDIT: Removed other advertising, I don't want to turn this into a plug for my services... if you have any questions. PLEASE PM me. Otherwise, keep this thread on track.
Offline net2522
  • lollollollol
« Reply #129 on: Tue, 01 May 2012, 15:41:40 »
^:thumb:
Offline tsangan
  • 1000/600
« Reply #130 on: Tue, 01 May 2012, 15:44:28 »
iMav is there a tentative close/ship date for these?
Keyboardless
Offline smknjoe
« Reply #131 on: Tue, 01 May 2012, 16:04:17 »
SSKs for everyone!
Offline rknize
    • metaruss
« Reply #132 on: Tue, 01 May 2012, 16:40:07 »
Quote from: keebler64;587528
Indeed...and that assumes that the controller requests high-power mode.  Otherwise we are limited to 100mA.  Looking at lsusb output, I don't think that the Poker requests 5 units.
I don't understand the obsession with bright LEDs these days.  Blue and white LEDs are offensive to the eyes.  To each their own, I guess.
This is probably the only reasonable option, unless it is somehow possible to modify the controller to request high-power.
Russ
Offline keebler64
« Reply #133 on: Tue, 01 May 2012, 17:17:10 »
Quote from: rknize;587577
Well, the modification that I was promoting was to utilize an ATMEGA32U4 or PIC24FJ256DA210 (Only USB MCU's I have on hand) to create a High Speed USB HID, and from that dedicate about 8 GPIO to a 8x8 Array doing PWM, with a A/D Pin wired to either a variable resistor, or do a switch/case w/ button statement to select variable brightnesses....
(I'm at work, so I'm OVER generalizing a lot of this for the sake of time..)
Other wise, only other way I could see doing anything, would be to replace the Poker MCU with our own custom controller. That's assuming it's not in a plastic blob, and that we can find a pin-compatible replacement. Does anyone have any close up pics of the Poker MCU?
Offline rknize
    • metaruss
« Reply #134 on: Tue, 01 May 2012, 17:37:02 »
Quote from: keebler64;587592
That would be quite fancy!  :)  You could do all kinds of interesting lighting effects if you dedicate an MCU to it.  :)
The controller is a Holtek HT82K94E:
http://www.holtek.com/english/docum/computer/82k94x.htm
Russ
Offline keebler64
« Reply #135 on: Tue, 01 May 2012, 17:55:54 »
Quote from: rknize;587605
Do we have a picture of the actual chip on-board? I want to see what kind of package it's in.
Offline mkawa
« Reply #136 on: Tue, 01 May 2012, 18:02:10 »
i don't care about leds, but i would like to be able to reprogram the thing..
could we swap these for the a pin compat butnflashable variant?
Offline mkawa
« Reply #137 on: Tue, 01 May 2012, 18:03:34 »
i believe it's an ssop but i'll check when i get home
edit: confirmed, it's the SSOP package. it's also about 1mm away from the edge of the board, so it's going to be difficult to fit anything else in there.
« Last Edit: Tue, 01 May 2012, 18:57:10 by mkawa »
Offline metafour
« Reply #138 on: Tue, 01 May 2012, 18:14:57 »
With 61 switches that's roughly 10 seconds a switch. How do you achieve this? Does the oven and hot air system do something to significantly impact the time it takes?
I'm not doubting you at all I'm just curious and unfamiliar with electronic soldering.
Offline keebler64
« Reply #139 on: Tue, 01 May 2012, 18:17:19 »
Quote from: mkawa;587623
It might be kinda tricky finding a user-programmable-pin-compatible chip, however, I've gotten lucky before. :)
If someone would be willing to offer up a pcb for testing, I see about modding an MCU onto it, and you can even have the board back. I just want to do it for the thrill of the challenge. :)
But really, what would be better than a Poker DIY, would be a Geekhack DIY that had a Pinout on the PCB for our own MCU. Hell, Soarer's Teensy Program loaded into an ATMEGA32U4 would be perfect, and there'd still be enough GPIO for various other mods.  It would save a lot of work on the programming side. Failing that, I can probably desolder the Holtek and build a crossover interface to our MCU of choice. It's not THAT hard.
Offline keebler64
« Reply #140 on: Tue, 01 May 2012, 18:19:30 »
Quote from: metafour;587629
Even if I just used a soldering iron. It only takes a few seconds per switch. Now, DESOLDERING, that takes a bit longer to clean each lead/contact/pin/pad, without damaging anything...
Offline alaricljs
« Reply #141 on: Tue, 01 May 2012, 18:28:03 »
Quote from: keebler64;587630
Been there done that, sorta... Phantom had a 'socket' for a teensy on it.  We've been discussing a new one here and on-board MCU is definitely an interest.
Offline popol
« Reply #142 on: Wed, 02 May 2012, 04:11:27 »
I don't have any soldering skill nor tools.
Does aluminium plate mounted Poker exists?
« Reply #143 on: Wed, 02 May 2012, 08:57:43 »
I still dont get how the plate will solve the flimsiness of the pcb, where is it supposed to be anchored???
Offline alaricljs
« Reply #144 on: Wed, 02 May 2012, 09:00:42 »
Since the plate is attached to all the switches it would work similarly to an anti-sway bar or the stabilizers on your keyboard.  Press one switch down and that pressure gets distributed into the plate and across all the switches and into the PCB.  Will it be just like a filco where the plate is what's mounted to the case?  No, but I bet you'd have a hard time telling the difference.
Offline keebler64
« Reply #145 on: Wed, 02 May 2012, 09:27:50 »
Quote from: alaricljs;588062
Where you might have an issue would be if the key switches do not snap in firmly across the board. My NEC was platemounted to the PCB and to the case, however, once I remove the rivets, it was noticeably more flexible due to the keys popping out of the plate. Now, it was still pretty damn firm without the rivets, but I could see situations like that being an issue. But I don't see the Cherry MX Switches popping out easily if they're also soldered to the board and there is enough plastic grabbing the plate.
Offline rknize
    • metaruss
« Reply #146 on: Wed, 02 May 2012, 11:14:07 »
The plate would work better if the top and bottom were flanged downward.  I know space is tight, but this would give the Poker the rigidity it needs.
Russ
Offline scriz
« Reply #147 on: Wed, 02 May 2012, 12:38:26 »
$200 and i have to put it together myself? Hrm..
Offline Wibox
« Reply #148 on: Wed, 02 May 2012, 13:03:00 »
Have a couple more questions ... all of my questions grouped here for covenience:
The plate looks like it's for the pure, any word on that?
Can we just buy plates?
Can we just buy PCBs?
Can we just buy those cherry keycaps?
Can we just buy those aluminium trays?
Are these sets limited in quantity?
Is there a cut off date for ordering?
Is there any estimates on first shipment dates?
Apologies if it's too soon to be asking, just curious! Thanks!
Offline tsangan
  • 1000/600
« Reply #149 on: Wed, 02 May 2012, 13:42:54 »
Quote from: Wibox;588258
The plate looks like it's for the pure, any word on that? Nothing yet
Can we just buy plates? Not sure, pretty sure yes
Can we just buy PCBs? No
Can we just buy those cherry keycaps? Not in this GB
Can we just buy those aluminium trays? Not in this GB
Are these sets limited in quantity? No
Is there a cut off date for ordering? Nothing yet
Is there any estimates on first shipment dates? Nothing yet
^that
Keyboardless
