Author Topic: Is the Rosewill RK9000's shell the same as a Filco MJ1/2?  (Read 1151 times)
Offline ty_moon
« on: Mon, 30 April 2012, 09:12:02 »
Just wondering if I can swap the case of the Rosewill with an old Filco case that I own. Also, is the Quickfire's case the same as a Filco TKL?
« Last Edit: Mon, 30 April 2012, 09:14:12 by ty_moon »
Offline alaricljs
  • I be WOT'ing all day...
« Reply #1 on: Mon, 30 April 2012, 09:14:19 »
Filco 87 key and Quickfire are very similar but are not interchangeable.  I don't know about the Rosewills tho.
Filco w/ Imsto thick PBT
Offline laffindude
« Reply #2 on: Mon, 30 April 2012, 09:16:39 »
Rapid's case is not exactly the same as Filco. The screw location is different. It is under F7 in Filco, and between F5 and F6 in Rapid.
