Author Topic: What do you use to design keycap sets?  (Read 7315 times)
Offline bavman
« on: Wed, 02 May 2012, 17:01:00 »
Like in the groupbuys theres always example layouts of how the keys will look with the colors, for example the cream cheese and green:
http://geekhack.org/attachment.php?attachmentid=40535&d=1329261885
Or all the ones from Round4?
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #1 on: Wed, 02 May 2012, 18:01:41 »
Adobe Illustrator is my preferred software.
Offline fstop
« Reply #2 on: Wed, 02 May 2012, 18:09:59 »
Hazeluff...? :biggrin:
I would assume people just used their favourite image editor program.
CM Storm Quickfire MX Reds
CM Storm Quickfire MX Blues
Filco Majestouch-2  MX Browns
RealForce 87uw uniform 45g
Offline bavman
« Reply #3 on: Wed, 02 May 2012, 18:12:00 »
Is there a template or something?
« Reply #4 on: Wed, 02 May 2012, 18:23:40 »
I used this one as a start...
But illustrator, or inkscape if you can't afford adobe or won't get it by other means is best. Reason is if you want to turn your mock up to something you can submit to SP, it's pretty much already done, just convert to SVG. For mock ups and stuff though for ideas etc, yeah any image editor is fine, whatever you have and are comfortable with.
« Last Edit: Wed, 22 August 2012, 21:44:20 by lysol »
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #5 on: Wed, 02 May 2012, 22:16:49 »
I use inkscape.
My templates in a zip attached to the thread in my sig.
Fight For Freedom. Stand with Hong Kongers
« Reply #6 on: Wed, 02 May 2012, 22:44:41 »
Inkscape is my vector graphics editor of choice. Here's the official 'site:
http://inkscape.org/
Linux, mac and windows (even portable).
Edit: Though my E-reader outputs SVG's which are vector, os with a steady hand, I could in theory export them :p
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #7 on: Wed, 02 May 2012, 22:49:48 »
Note that if you use Inkscape to design SVGs for use by SP, you have to scale everything by 80% since SP uses Illustrator.  Their internal point-to-inch ratios are different.
This has no bearing on mockups, of course.
Offline Frenden
    • http://frenden.com
« Reply #8 on: Fri, 15 June 2012, 10:23:18 »
Thanks for posting links to the vector templates. Does anyone know where a fella could get a 3D model of a cherry keycap? I want to drop it into Zbrush and sculpt/3D print the results.
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
Re: What do you use to design keycap sets?
« Reply #9 on: Wed, 22 August 2012, 17:07:10 »
Could someone link up a vector template again? I want to tinker around in Inkscape with a few ideas.
« Reply #10 on: Wed, 22 August 2012, 21:54:11 »
Fixed broken link in old post.
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #11 on: Wed, 22 August 2012, 21:55:50 »
So is a PNG a vector file or is that not even really needed?
Offline Lethal Squirrel
  • I <3 60%
« Reply #12 on: Wed, 22 August 2012, 22:12:44 »
a PNG is an image with a transparent background
« Reply #13 on: Wed, 22 August 2012, 22:48:11 »
I just use it as a background to arrange things. If you really want a vector template there are some nice ones on wasdkeyboards site.
« Reply #14 on: Thu, 23 August 2012, 23:13:23 »
PNG's (Portable Network Graphics) are raster files: They store the data as pixels, whereas vector files store the data as formulae, shapes, bezier curves, etc. PNGs have support for the alpha layer, so they can have clear backgrounds, though this is by no means necessary, just useful.
Offline TotalChaos
  • Indy Game Coder
« Reply #15 on: Sat, 15 December 2012, 20:36:21 »
PNG files are not vector files.  I don't particularly recommend trying to send WASD a PNG file.  :)
Offline KuhnTang
  • Game of Thrones
« Reply #16 on: Sun, 16 December 2012, 00:34:14 »
Good thread, I was wondering myself.  I actually made a few mock ups using excel, but they look pretty trashy.  they're only good to see the contrast in colors.
