Author Topic: Are Filcos Worth It?  (Read 4364 times)
Offline smknjoe
« on: Thu, 03 May 2012, 11:27:10 »
They are about $180.00~ from the keyboardco including shipping but not Customs to TX. Anybody here know about how much Customs will be? My Leo was only $120 shipped to the door and the quality is superb.
SSKs for everyone!
Offline alaricljs
  • I be WOT'ing all day...
« Reply #1 on: Thu, 03 May 2012, 11:28:18 »
You could check Amazon and see if it's in stock there (via keyboardco).
Filco w/ Imsto thick PBT
Offline fstop
« Reply #2 on: Thu, 03 May 2012, 11:31:20 »
If you're in the USA it's very unlikely that you will be paying custom taxes on it ordering from Keyboardco directly. Plus, as stated if you find them on Amazon they're anywhere from $140-$170 depending on which model you want. The stock in Amazon is somewhat limited right now but if you wait till mid-June there will be an inventory update with loads of good options (including a Filco with mx reds!).
And alternatively, you can find a used or mint condition in the classified forums for as low as $120 shipped. I sold mine recently for around that price.
Edit: and yes they're worth it lol! Filcos are at the top of list in terms of quality. While they won't be miles ahead of your leopold, I still prefer Filcos.
CM Storm Quickfire MX Reds
CM Storm Quickfire MX Blues
Filco Majestouch-2  MX Browns
RealForce 87uw uniform 45g
Offline oneproduct
  • @Ubisoft
« Reply #3 on: Thu, 03 May 2012, 11:33:15 »
Are you interested in fullsize or tenkeyless? If you're after a fullsize WASDkeyboards is a very good, cheaper alternative that is considered to be very comparable to a Filco. The CM storm is also fairly well received so long as the branding doesn't bother you and assuming you're after blue or red switches since I don't think it comes with black or brown ones here yet.
I don't really think you'd notice that much difference in quality, you have to be /very/ discriminating to notice significant differences between these. The Leopold would be a bit different because it uses different stabilizers than the Filco but the WASDkeyboard and CM storm use the same type.
Layout: Colemak
Offline alaricljs
« Reply #4 on: Thu, 03 May 2012, 11:35:43 »
The Quickfires can be had in all 4 major switches at mechanicalkeyboards.com
Far cheaper deals have been seen on the blue switches at places like NCIX.
Offline eth0s
  • Peace & Love
« Reply #5 on: Thu, 03 May 2012, 11:35:56 »
Quote from: fstop;589117
+1
Offline smknjoe
« Reply #6 on: Thu, 03 May 2012, 11:47:06 »
Checked Amazon and contacted KBco. They said they would be restocking Amazon soon but not TKL Black Ninja. I didn't ask about the TKL with standard keycaps. I never use the numpad or else I would consider full size boards.
SSKs for everyone!
Offline fstop
« Reply #7 on: Thu, 03 May 2012, 11:50:18 »
If youre looking for TKL blacks you will easily find one in classified, just post up a WTB thread. They have the lowest resale value and are hard to sell because not many people prefer black switches - not to say that they are bad, they're just the least popular switch option.
You might not find it with ninja keycaps, but I'm sure you'll find a good deal on one.
Offline notscott
« Reply #8 on: Thu, 03 May 2012, 15:29:17 »
Quote from: smknjoe;589130
Really? Damn.. I was really hoping they would be restocking TKL Black Ninjas. I have an Amazon gift card I've been saving to buy one with.
Offline Daniel Beaver
« Reply #9 on: Thu, 03 May 2012, 15:48:45 »
Filcos are not worth $180, but they are certainly worth $120.
Home: Topre Realforce 87W45  /  Mionix Naos 3200
Work: Topre Realforce 87B  /  Microsoft Intellimouse Explorer 3.0
Offline smknjoe
« Reply #10 on: Thu, 03 May 2012, 16:47:52 »
Quote from: Daniel Beaver;589348
To me it seems like the Leopold and Filco are VERY similar and the Leopold is cheaper here in the US at the moment. I know they have different stabilizers and keycaps, but those seem to be the main differences. They are both designed by the same guy, look almost identical, and are made in Taiwan.
That was for the black case and black switches. I didn't ask about other models.
SSKs for everyone!
Offline Reptile
« Reply #11 on: Thu, 03 May 2012, 16:49:26 »
Quote from: fstop;589132
I agree. You would get an awesome deal for blacks
sent from my mobile
Home:Realforce 87UB 55g
Work:Leopold FC700R Ergo Clears
Offline Namkung
« Reply #12 on: Thu, 03 May 2012, 18:03:04 »
As with most things, there is a point where something no longer becomes proportionally better (price to quality wise)
are filcos better than leopolds? yes.
is it like $50+ better than leopolds? no.
you decide where you want to stop.
* Proud winner of the first GH SC2 tournament *
REALFORCE 87UB 55g
REALFORCE 87UW 45g
Offline Namkung
« Reply #13 on: Thu, 03 May 2012, 18:06:59 »
iPads are worth  more than some kids' organs!
REALFORCE 87UB 55g
REALFORCE 87UW 45g
Offline smknjoe
« Reply #14 on: Thu, 03 May 2012, 18:37:41 »
Quote from: ripster;589451
Are $500 iPads worth more than $500 Topres?
Yes.
The iPad doesn't have those stupid DIP switches.
Don't get me started. They lock their ***t down too much! I agree otherwise.
SSKs for everyone!
Offline Awful
  • Don't Topre.
« Reply #15 on: Thu, 03 May 2012, 18:51:55 »
Yes they are, and if you're impatient it's worth the extra money to get one from Keyboardco and not Amazon. In my opinion.
I hate everything.
Offline smknjoe
« Reply #16 on: Thu, 03 May 2012, 19:06:59 »
That's almost double what a new Leopold costs. Do you think they are built that much better? I'm sure I'll end up getting a Filco, but I think that's a bit much.
SSKs for everyone!
Offline aznsilvrboy
« Reply #17 on: Thu, 03 May 2012, 21:46:27 »
Does Amazon US ship Filcos to Canada?
Offline rocknrob
« Reply #18 on: Thu, 03 May 2012, 22:31:52 »
Quote from: Awful;589483
Why keyboardco instead of Amazon? Amazon I think has the best return policy anywhere.
Offline Awful
  • Don't Topre.
« Reply #19 on: Thu, 03 May 2012, 22:34:11 »
Quote from: rocknrob;589611
I was assuming Amazon was out of stock in the particular keyboard he wanted. Keyboardco is the company amazon gets their Filcos to sell.
I hate everything.
Offline squarebox
  • In Omnia Paratus
« Reply #20 on: Thu, 03 May 2012, 22:35:42 »
Depending on which model you are after, you can get some cheaper at PC|home global and shipping is only USD$10
Link : http://global.pchome.com.tw/?mod=store&func=style_show&SR_NO=DCAH1Z&tm=u
Filco Yellow Edition  | Filco Brown | Filco 2 Brown TKL | G80-1950 | G80-3494 | G80-11900 | Leopold FC500R | Noppoo Choc Mini
Offline rocknrob
« Reply #21 on: Thu, 03 May 2012, 22:45:30 »
Quote from: Awful;589614
That's cool. I thought you meant it was a better idea to buy from Keyboardco overall. Right now Amazon has white tenkeyless with a couple differently switches and black with black switches I think.
Offline smknjoe
« Reply #22 on: Thu, 03 May 2012, 23:01:59 »
Was looking for TKL black switches. I like the blues, but they are still a little light. I want to try blacks and clears. Reds sound too light for me.
SSKs for everyone!
