Author Topic: Doubleshots or custom lasered?  (Read 7652 times)
Offline Netdewt
  • OLKB
« on: Thu, 03 May 2012, 22:59:58 »
I bought a white keyboard because I love the look of dark keycaps on a white board. What should I do? Wait for doubleshots or get a custom WASD set?
Example (not mine):
« Last Edit: Thu, 03 May 2012, 23:46:07 by Netdewt »
Offline audukent
« Reply #1 on: Thu, 03 May 2012, 23:08:03 »
ohhh, what a very nice board my friend.  Love it! Thumbs up!
Double shots ftw.
[LZ-GH - 62g mx greens and 62g mx clears]    [Ducky Shine - mx browns]    [RACE mxMini - mxreds]  [POKER II - mx Blacks]    [KPAD - 62g mx blacks]
Offline Netdewt
  • OLKB
« Reply #2 on: Thu, 03 May 2012, 23:42:40 »
Sorry that one is not mine, just one I like! I have a white stock TKL Leopold.
Offline Hak Foo
  • Make America Clicky Again!
« Reply #3 on: Thu, 03 May 2012, 23:53:25 »
Doubleshots have a rich, bold colour which does not fade.
Dark Lasered to light can fade pretty fast.  My Ducky 1008XM is only a few months old, and there's a huge difference in contrast between some of the well-used keys and some of the rarely used ones.
Overton130, Box Pale Blues.
« Reply #4 on: Sun, 06 May 2012, 23:35:09 »
I'm preferential to PBT, so I'd go with lasered PBT were I you. Dyesub PBT is, of course, the best option.
If you like dark keycaps with lighter legends, you'll have to get doubleshot. If you're okay with gold legends, etc. Lasering is good. Either way, I'd recommend PBT.
Offline snowboarder3
« Reply #5 on: Sun, 06 May 2012, 23:36:21 »
WASD keys feel cheap IMO. Hate  the lack of texture. OP, depends which doubleshots you're waiting for. If it is something like red/black or creamgreen then definitely get the DS, but if it's something like R4 you'll be waiting for a bit... And by a bit I mean forever.
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #6 on: Sun, 06 May 2012, 23:40:04 »
dat doubleshot!
Offline inlikeflynn
  • file not found
« Reply #7 on: Sun, 06 May 2012, 23:42:24 »
Quote from: snowboarder3;589960
nah, I think his wait will be not so long to match the OP picture :peep:
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
« Reply #8 on: Mon, 07 May 2012, 00:45:24 »
Quote from: inlikeflynn;589966
Yeah, just ask the people from round3 still waiting for their replacements to complete their sets.
Offline N8N
« Reply #9 on: Sat, 12 May 2012, 11:40:22 »
I think that comment was that with WASD's plans for PBTs and the color options planned a Dolch-esque set in lasered PBT is a possiblity soon.  Unfortunately last I read was that while they were originally planning on introducing them later this month, that's been pushed back due to supplier/mfg. issues.
Offline Wildcard
  • When caffeine isn't enough
« Reply #10 on: Sat, 12 May 2012, 11:48:50 »
I prefer thick doubleshots to thin doubleshots. However, even thin doubeshots are nicer then lazered. Unless you're want that oktau style of blanks with lazered letters which isn't bad.
I agree with Hak Foo, double shots just look so sharp and keep that look over time. Been using a new set of Cherry DS for about 6 months now and I love 'em.
Offline N8N
« Reply #11 on: Sat, 12 May 2012, 11:52:13 »
problem with DS is that they get shiny...  if a little wabi-sabi doesn't bother you then they're great though.  Dye subs would be best of all but good luck finding them for a reasonable price!
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #12 on: Sat, 12 May 2012, 11:58:03 »
Going with lazered is only worthwhile in my opinion if you're going REALLY custom. As in you want to use unique font, or icons for every key or something like those multi key art style. However, custom sets of dyesubs looks like it will be an option soon perhaps, which would be even better way to go. You're more limited on keycap color with dyesub, but have the full run of legend color with more complexity which makes it even.
For doubleshots I also agree Cherry is where it's at. Sure they don't have quite as many color choices, and the ones other than black/white are much harder to find but they are so nice.
Offline Netdewt
  • OLKB
« Reply #13 on: Sat, 12 May 2012, 13:49:00 »
I don't really mind shiny keys in principle, but in reality Iu might want them to be all the same. Has anyone purposely shined all of their keys? I have a buffer and plastic polish... haha.
Doubleshots soon.
Offline Netdewt
  • OLKB
« Reply #14 on: Wed, 06 June 2012, 15:40:58 »
Here's my result. Can't use this space bar though, gotta wait for a Leopold one.
Thanks inlikeflynn!
Offline Internetlad
« Reply #15 on: Wed, 06 June 2012, 15:47:06 »
Like that look, it's pretty awesome lol.
I want to go for a board with engraved keys, as I think that's cool.
"Beep . . . Beep . . . Beep" -Sputnik I
Offline Spartan
« Reply #16 on: Wed, 06 June 2012, 20:19:49 »
Quote from: Netdewt;608729
Thanks inlikeflynn!
Where did you get that big font capkey set? I could use a set like that for my damn vision issue.
Offline Netdewt
  • OLKB
« Reply #17 on: Wed, 06 June 2012, 21:32:34 »
I bought a set from a member here, but you can still order one from the round 4 group buy.
Offline inlikeflynn
  • file not found
« Reply #18 on: Wed, 06 June 2012, 22:35:42 »
Thanks inlikeflynn!
Looking good on there! Much better than the stock crappy keys.
You could always try modding that spacebar to make it fit the leopold, there is a guide somewhere in the wiki section.
Or else there are a couple local guys who have done it I know before on other keys, which maybe would do it here as well
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline Spartan
« Reply #19 on: Thu, 07 June 2012, 01:10:55 »
Quote from: Netdewt;608929
I went into the group buy thread and I'm.......dazed. I'm a newbie to this site and I'm not sure how the entire group buy thing works.
Offline Wildcard
« Reply #20 on: Thu, 07 June 2012, 01:48:34 »
Quote from: Spartan;608992
You'll get it eventually. Usually first post specifies what's in the group buy and how orders are being collected and once that's past, orders close and invoices go out with specified payment methods. And after most everyone follows through with their orders, everything is purchased, manufactured, possibly corrected ;) and finally... eventually sent out.
TL;DR lots of great work by the geekhack community in turning cash into plastic cubes
Offline Zifle
  • Nyaaa
« Reply #21 on: Thu, 07 June 2012, 05:00:49 »
Here's the link to R4 -> http://geekhack.org/showthread.php?20485-taking-orders!-Double-shot-replacements-ROUND-FOUR!
To order a set of round 3 keycaps (pictured by Netdewt), you'll want to send a pm to 7bit_R4, containing something along the lines of:
ROUND3/[style]
your@email
You can see the different styles available here.
You should receive an email with further instructions the next time 7bit runs the bot. Keep in mind though, that the gb is nearing it's completion, so there is a limited amount of sets available. Look for a post with the current list in one of the last pages of the R4 thread.
If you have any further questions regarding R4, you can always ask in the thread, 7bit usually responds fairly quickly, and will be happy to help you get the exact set that you need for your keyboard!
Welcome to Geekhack ^^
I like cats.
Offline Netdewt
  • OLKB
« Reply #22 on: Thu, 07 June 2012, 10:04:24 »
I need to update my pixel art thing.
Offline modulor
« Reply #23 on: Thu, 07 June 2012, 11:09:20 »
The R3 looks really good on your Leo!
NP-R (soon) | 21XX | Leggera-G Acrylic | Classic TKL | Frog TKL 8K | GH60revC | R1 86U 45g | G80-2100HDU | G80-3000HAU | G80-3700HAU | QFR V1 | FC200R | Poker X | G80-11900LUMEU
Offline Netdewt
  • OLKB
« Reply #24 on: Fri, 08 June 2012, 08:09:32 »
Thanks. I like it.
Actually I'm not even that disturbed by the useless keys anymore (print, scroll lock, pause) and the non-Apple modifiers since they don't have Windows icons on them. I probably didn't need to buy all that R4 stuff, but it seems like keys on this site are pretty easily resale-able. #1 complaint from a design perspective is that the BACK SPACE and CAPS LOCK keys have a larger font than the rest of the keys. It's a little odd. But, that said, I really like it.
Offline Netdewt
  • OLKB
« Reply #25 on: Sat, 09 June 2012, 22:46:44 »
I keep finding excuses to use this keyboard now... keys are so awesome.
Offline net2522
  • lollollollol
« Reply #26 on: Sat, 09 June 2012, 22:50:09 »
^ (Jelly you)
