Author Topic: New Filco Keyboard Has Wrong O Key  (Read 2998 times)
Offline BigBadWolfie
« on: Fri, 11 May 2012, 21:10:37 »
I just received my Filco Majestouch-2 tenkeyless keyboard from amazon and found that the O key is a Q key. I'm kind of bummed out about it. Do you think it was a QC problem or the keyboard was somehow used and someone swapped their Q key for the O key? I'm thinking it's a QC problem.
I assume my only option is to return the keyboard for another one. Sucks.
Offline captain
« Reply #1 on: Fri, 11 May 2012, 21:13:28 »
Your only option is to start loading up on DS keycaps from every GB you can find!  ;-P
PS: pix, or it didn't happen
Welcome to geekhack -- where we like to type -- but don't care so much about reading.
Offline lorem3k
    • http://twitter.com/#!/lorem3k
« Reply #2 on: Fri, 11 May 2012, 22:32:37 »
Yqu shquld just stqp using that letter.
Leopold FC200RT/AWN | Logitech G400 | Sennheiser HD25-1 II | Pounds in the fridge, hundred stacks in the armoire
« Reply #3 on: Fri, 11 May 2012, 22:48:01 »
I can type without looking at the keyboard so it isn't a problem per se but I'm not one to pay that type of money for some flaw that should not be there and can be avoided.
I would be happy to upload a pic but I'm not well versed with free pic hosting sites.
Offline 1839cc
« Reply #4 on: Fri, 11 May 2012, 23:31:15 »
Just attach it to your post.
i have seen unix admins with john deere trucker hats, and even seen a man in a nascar shirt correct a passerby's klingon.
Offline mickd
« Reply #5 on: Sat, 12 May 2012, 00:11:16 »
Been over a year and the only 2 letters on my stock filco keys that have faded are M and L. There's a few that are half gone (C, N, K, O, S).
Offline captain
« Reply #6 on: Sat, 12 May 2012, 04:08:50 »
I use ls for 1s all the time on my Smith-Corona.  ;-)
Offline Nunez
  • BACK!
« Reply #7 on: Sat, 12 May 2012, 04:22:32 »
Quote from: BigBadWolfie;590221
tinypic.com is quick and easy, but so is just attaching it to your post.
I miss Ripster :(
HHKB Pro 2 || KBC Poker || Filco MJ2
« Reply #8 on: Sat, 12 May 2012, 07:35:21 »
How can I attach an image? When I click "insert image" it asks for a url link.
Edit: I spoke to amazon and they are willing to give me a $15 refund. I'm tempted. Should I do this? I guess having the wrong O key might affect the keyboard's resale value but I'm unlikely to sell and the letters probably will get worn out with use? Still, it kind of sucks not having everything perfect.
« Reply #9 on: Sat, 12 May 2012, 08:39:08 »
I would take the $15. You may well find a key later.
I may have a used ABS one that I would sell cheap, but it will be beige and may not have the right profile.
- Oliver Willis 2026-08-01
Offline laffindude
« Reply #10 on: Sat, 12 May 2012, 08:40:58 »
I'd take the refund and put it toward a set of replacement caps. You'd want to replace it eventually due to wear.
Offline mickd
« Reply #11 on: Sat, 12 May 2012, 09:47:00 »
I would take that refund! You'll be getting a Filco for a really good price after that refund.
Offline eth0s
  • Peace & Love
« Reply #12 on: Sat, 12 May 2012, 13:55:02 »
Quote from: BigBadWolfie;590146
WOAH, don't do anything yet!  PM me a pic, I may be willing to trade you for that "defect", if it is real.  I can trade you an entire Filco keyboard, or just the keycaps, or w/e.  But I need to see it first.
Offline ChaoticKinesis
« Reply #13 on: Sat, 12 May 2012, 15:44:51 »
It's just a keycap, which is easily replaced. I'm sure if you contacted Keyboard Co (assuming that's who you bought from) they can send you an O.
Offline captain
« Reply #14 on: Sat, 12 May 2012, 16:42:03 »
Why is everyone around here always looking for another "O" to fill that empty space?  ;-P
No one seems to appreciate a good pun anymore.
« Last Edit: Sun, 13 May 2012, 05:33:36 by captain »
