Author Topic: Comparing Filco's  (Read 1315 times)
Offline Syrislol
Comparing Filco's
« on: Mon, 14 May 2012, 16:14:02 »
Hey guys, I finally decided to buy a filco keyboard to represent my first mechanical keyboard purchase. I found (through ripster) a relatively inexpensive website which sells filco's, however, it is not in English. I've managed to work and navigate my way to pick out 4 Filco keyboards, they all have some key features in common.
-Cherry MX Brown
-Filco
However some of them are "Majestouch" and others are labelled as "N-Key Rollover"
here are the links (Due to being a new poster, I can not post a full link, so add "=82", or "=15" to the end of the link provided
http://www.filco.com.tw/product.php?page_id=23&product_id
#1 - =82
#2 - =15
#3 - =57
#1 is the most expensive, and I would like to know why as well.
Thanks for the help :)
Offline laffindude
Comparing Filco's
« Reply #1 on: Mon, 14 May 2012, 17:58:05 »
Filco.com.tw is the Filco distributor in Taiwan. NKEY is out of production old model. They don't remove old out of stock models from the site.
http://www.filco.com.tw/product.php?page_id=23&product_id=52 <- They used to be a lot cheaper.
Offline laffindude
Comparing Filco's
« Reply #2 on: Mon, 14 May 2012, 18:05:34 »
Sure, but the NKRO one was a separate model from the regular Majestouch, and was sold alongside it. It used those gold Filco emblems, where the standard ones had silver.
