Author Topic: SP color ring question: what color is BFM?  (Read 1512 times)
Offline gimpster
« on: Fri, 18 May 2012, 16:30:54 »
I've got a question for anyone else with an SP ABS color ring. I noticed today as I was going through my blues that I have 2 colors that are both labeled the same. I was wondering if anyone else can help identify which one is the correct color and what the color code for the other one should be. Here's a picture, both of them are labeled "BFM".
[ Attachment Invalid Or Does Not Exist ] 50776[/ATTACH]
-Ryan
Offline shawn o
« Reply #1 on: Fri, 18 May 2012, 17:01:54 »
Blue looks like BFU.
BFM I have is extremely light blue almost white, but has slight blue tint.
White you have looks like WFM actually.
Offline gimpster
« Reply #2 on: Fri, 18 May 2012, 18:30:57 »
Yah, the color is off a little in that photo, the lighter BFM in that photo is definitely a light "cloud blue" kind of color. I think you're right about the darker one being BFU, because I don't have any other swatch that's labeled that color. Thanks very much!
-Ryan
Offline ekw808
  • Ekw
« Reply #3 on: Fri, 18 May 2012, 20:26:14 »
I wish they had a good indigo purple color, all their purples are wack.
[One Keyboard at a time]
Offline gimpster
« Reply #4 on: Fri, 18 May 2012, 20:29:19 »
Yah, that would be a nice color to have...I was trying to find a good lime green today but they just don't have any in ABS...
-Ryan
