Author Topic: Ducky Shine - Backlighting  (Read 2307 times)
Offline therecorder
« on: Sun, 20 May 2012, 20:47:25 »
Have one.  When backlighting is off, the "1X" is still lit.  Any way to turn this off?  Kind of a distraction.
Offline Kortekk
« Reply #1 on: Tue, 22 May 2012, 17:31:21 »
I don't believe there is a way to turn it off.  I have the same keyboard and never found a way to do this.
Offline therecorder
« Reply #2 on: Tue, 22 May 2012, 17:34:36 »
Pity...
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3 on: Tue, 22 May 2012, 18:24:54 »
Remove the led? It's like other things that have a bright as 1000 suns led when the device is off. I never understand this.
Offline therecorder
« Reply #4 on: Tue, 22 May 2012, 18:33:44 »
Good idea.  Guess you can teach an old dog new tricks (at least this old dog :redface:)
Offline flemeister
« Reply #5 on: Thu, 21 June 2012, 11:03:24 »
Cover the LED with a bit of blu-tack. Even if you can't get the perfect amount on there to block it off completely, you'll at least significantly dim it. :)
« Reply #6 on: Sat, 23 June 2012, 03:06:27 »
Replace the key cap with a non-transparent one?  The LED will still shine, but won't shine through the key.
It kinda stands out on mine - one blue light amidst all the red backlighting elsewhere (oh, and caps lock too, but not that I use that key much).
Offline ShakeR
  • * Commercial Vendor
    • http://mechanicalkeyboards.com
« Reply #7 on: Sat, 23 June 2012, 10:07:37 »
Quote from: therecorder;596776
The lights on the top right 'media' keys should have 1x, 2x, 3x, and 4x on them.  It represents the speed at which the keys are sent to the computer.  2x - 4x are all used for gaming.  4x is actually very funny if you try typing with it as it will lllllloooooookkkkkkkkkkk lllllliiiiiiikkkkkkkeeeeee tttttthhhhhhiiiiiiiiisssssss.
We get asked this question often, but there is no way to turn all 4 of the lights off at once.  1 of them always has to be on.  Like rowdy mentioned, you may go with a non-translucent cap to minimize the effect.
MechanicalKeyboards.com - What do you type on?
Offline therecorder
« Reply #8 on: Sat, 23 June 2012, 10:33:44 »
ShakeR - Thanks for the info.
