Author Topic: DAS ULTIMATE- WILL IT TAKE FILCO KEYCAPS?  (Read 5831 times)
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« on: Mon, 21 May 2012, 08:27:22 »
Noob question...........justing wanting to make sure. Will a Das except Filco keycaps without any issues including the spacebar? Stabilizers?
I'm sure there is a thread already covering it somewhere, but I did not look.
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #1 on: Mon, 21 May 2012, 09:15:03 »
Yes it's 100% standard, compatible with Filco / wasd / KBC / etc after market keycaps.
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #2 on: Mon, 21 May 2012, 09:17:17 »
YES
Offline laffindude
« Reply #3 on: Mon, 21 May 2012, 09:24:18 »
Have to remind imav to turn back on the decapitalization thing.
Offline tersagun
« Reply #4 on: Sun, 27 May 2012, 07:02:47 »
And I'll have a question regarding DAS keycaps (didn't want to start a new thread).
I've used DAS, Blackwidow, Zowie and TTeSports and so far, DAS was clearly the best in "quality". Too bad I had to trade it to get 2 keyboards ;-)
My question is; how does the "DAS keycaps" are named, what is that feeling similar to velvet, if you know what I mean.
Zowie is similar to DAS, for instance, but Blackwidow has a very different keycap feel. I just would like to know how to describe DAS keycaps for my future keyboard choice.
Thanks in advance!
« Reply #5 on: Sun, 27 May 2012, 07:33:41 »
KBC / WASD abs keycap is most similar feeling aftermarket set. Perhaps all made in same factory.
« Last Edit: Sun, 27 May 2012, 07:36:02 by lysol »
Offline longweight
  • philanthropist
« Reply #6 on: Sun, 27 May 2012, 13:13:44 »
YES IT WILL AND THE CAPSLOCK WILL WORK.
Offline yearn4
  • formerly known as 4en
« Reply #7 on: Sun, 27 May 2012, 13:58:07 »
if only das made tenkeyless keyboards.
Offline therecorder
« Reply #8 on: Fri, 01 June 2012, 05:30:30 »
Does DAS or anyone sell a replacement set of their "Professional" keycaps, to replace the keycaps on their "Ultimate"?
« Reply #9 on: Fri, 01 June 2012, 09:48:12 »
I think the only keycaps DAS sells are the WASD sets:
http://store.daskeyboard.com/WASD-Key-Set-Without-Inscriptions/dp/B004JPGYS4
That said, I would grab some third-party PBT keycaps to replace them, if I were you.
http://www.vendio.com/stores/E-sports-Gaming-equipments/category/pbt-key-caps/catId=3982960
Offline featherodd
