Author Topic: Help me choose my first mechanical keyboard  (Read 2548 times)
Offline Ihales
« on: Tue, 22 May 2012, 08:50:45 »
Hi,
I would like to buy my first mechanical keyboard and I would appreciate your tips. I will use it for typing and gaming. I don't need fancy stuff like additional buttons, but good quality is important for me.
My preferences:
price under 130 €
brown switches
full size
6 or n-key rollover.
backlighting isn't necessary but it would be nice bonus.
It must be available in Europe.
I like Das keyboard professional silent, but I am not sure if it is the best what I can get for that prize. Could you confirm my choice or give me some better options?
Thanks.
Offline funxion
« Reply #1 on: Tue, 22 May 2012, 09:04:00 »
Here is a Filco brand new from The Keyboard Co. based in the UK. As shown, it's £100 (which converts to approximately 123.65€). This meets your budget and, from a general consensus, seems to be favored over the Das. I don't really know where you are in Europe, but if you go to The Keyboard Co.'s main website, they have alternate layouts for sale as well.
Brown switches are a good place to start, so you made a great choice there. I'd personally say go with the Filco or the Das and to look no further - either one will be a good starter! Do note that the Das has a glossy finish and is said to be a dust magnet.
Crush80
Filco MJ2 TKL
Offline Ihales
« Reply #2 on: Tue, 22 May 2012, 10:12:21 »
Thanks, I didn't know that Filco is available in Europe. I guess now it will be just personal preference whether Das or Filco.
Offline funxion
« Reply #3 on: Tue, 22 May 2012, 10:50:16 »
Quote from: Ihales;597541
No problem! If you don't mind me asking, what keyboard(s) have you used previously? Also, what will your primary use be for the keyboard? I can personally attest to the Filco being a great keyboard for all around use. I type a lot, game a lot, and do pretty much a bit of everything and my MJ2 with browns has been nothing but perfect!
Crush80
Filco MJ2 TKL
Offline Ihales
« Reply #4 on: Tue, 22 May 2012, 11:13:40 »
Quote from: ripster;597564
Welcome to Geekhack!
Quote from: funxion;597576
My current keyboard is Logitech Wave, it isn't bad keyboard but some keys are really hard to press (they get little stucked). I spend about 60% time on computer with typing and the rest is playing games (mostly MMOs), that why I choose brown switches. Blue switches would be probably too loud at night.
Offline Ihales
« Reply #5 on: Wed, 23 May 2012, 02:29:46 »
I have one more question. I am really considering Filco and I wonder about quality of lettering. Do they wear off like on classic keyboards or do they have some better design?
If they wear off I will go for ninja version otherwise normal majestic 2 is fine for me.
Offline Djuzuh
« Reply #6 on: Wed, 23 May 2012, 02:33:24 »
they will wear off.
Offline Ihales
« Reply #7 on: Wed, 23 May 2012, 03:02:00 »
Thanks for quick response.
Offline Djuzuh
« Reply #8 on: Wed, 23 May 2012, 03:11:29 »
But if the ninja version scares you too much (you are not a confident touch typist), you can always buy another keyset afterwards (Filco ABS sets go out for 20, 30$, and PBT sets(better quality) go out for 50*60 $ (PBT sets for iso layouts (everything with a two line enter key) are impossible to find atm), or even a nice ABS doubleshot keyset in a group buy (still abs, but the legend won't fade).
But it will only be qwerty most of the time.
« Last Edit: Wed, 23 May 2012, 03:19:33 by Djuzuh »
Offline Ihales
« Reply #9 on: Wed, 23 May 2012, 03:28:30 »
No, ninja doesn't scare me :) I need only special symbols which I don't use very often. Perhaps without letters on top I will start to type faster.
Offline Occi
    • http://www.thevoid.no
« Reply #10 on: Wed, 23 May 2012, 06:35:55 »
Quote from: Ihales;597589
I experienced this with my Logitech Wave aswell, has to be a design flaw by the engineers or something. The key printing was also absolutely horrible, my 's' was gone after just a month or so.
And I was in the same position as you; scared of the key printing to tear off on my precious Filco and therefore bought the Ninja version. Remember; when you buy a mechanical keyboard which uses the common switches thare MXs are it's easy to get replacements (although not æøåä and such).
