Author Topic: Looking for English/Korean text keycaps for Leopold FC200RT/AB  (Read 3755 times)
Offline SkyBlaze
i'm looking for key caps that have both English and Korean on them that fit my leopold FC200RT/AB. As well a way to make my left windows key not functional and still covered up, while looking good. I've seen the key cap blockers but did not look good to me. Hopefully I'm not ask for too much here. thanks in advance.
Offline Djuzuh
« Reply #1 on: Wed, 23 May 2012, 04:38:22 »
If you don't find anyone offering the very specific cap combination, you can hit up QWERKEYS to make them customely for you.
And aout your windows key, you can either disable the key with some piece of software, or you can easily fill the key up around the central stem, so you can't press it down anymore.
Offline SkyBlaze
« Reply #2 on: Wed, 23 May 2012, 04:48:52 »
Oh , I didn't know that about the keys and info about qwerkeys I'll look into that. Thanks
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3 on: Thu, 24 May 2012, 10:05:29 »
If on windows enter this:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout]
"Scancode Map"=hex:00,00,00,00,00,00,00,00,02,00,00,00,00,00,5B,E0,00,00,00,00
*there should be no spaces*
disable left windows key only, you can still have the right one. Convenient as it gets it out of the way for gaming, but you still have one for command shortcuts.
