Author Topic: Price Check- What's it Worth?  (Read 4322409 times)
0 Members and 6 Guests are viewing this topic.
Offline nickheller
  • Cherry ML life
  • Trade Count: (2)
    • hickneller.com
Re: Price Check- What's it Worth?
« Reply #5000 on: Fri, 05 June 2015, 10:19:22 »
KUL ES 87 MX Browns that I spilled soda on a week ago, cleaned it, everything works, expect the function layer keys (Media controls) only work on my front panel usb connectors, and not when plugged in to my computers motherboard. Good condition other than that, had to open it up to clean it so no warranty with KUL.
Offline flamf
  • Trade Count: (0)
« Reply #5001 on: Fri, 05 June 2015, 10:37:14 »
Caps are doubleshot, so its 100-200$ range or less?
Offline quochung1989
  • Vintage Cherry Collector
  • Trade Count: (0)
  • Frenzy Classic.
« Reply #5002 on: Fri, 05 June 2015, 10:44:47 »
I guess 150-200$. Waiting to see photek's idea.
  • Trade Count: (1)
« Reply #5003 on: Fri, 05 June 2015, 10:55:38 »
I'd say $150~. The case on its own is worth $50-75. The PCB is not worth too much. The caps are very rare because of the layout, and I'm sure anyone who uses that layout will really want them, but they're doubleshot and used so probably not worth tonnes.
$150 is assuming the caps are in good condition, no shine, but some evidence of use. If they are really pristine maybe more. If they are shiny and heavily used maybe less.
Offline flamf
  • Trade Count: (0)
« Reply #5004 on: Fri, 05 June 2015, 11:03:00 »
Much appreciated, thank you both :thumb:
Offline metal369
  • Trade Count: (1)
  • Singlepath
« Reply #5005 on: Fri, 05 June 2015, 19:22:14 »
Price check on oktoberfest clickclack- mx blank
Hi there!
  • Trade Count: (1)
« Reply #5006 on: Fri, 05 June 2015, 19:29:43 »
Around $100-150 I think, but prices change pretty often.
Welcome to Geekhack by the way, I've seen your pictures on OTD :)
Offline metal369
  • Trade Count: (1)
  • Singlepath
« Reply #5007 on: Fri, 05 June 2015, 20:39:09 »
Oh, thank you very much. I saw your epic corsa, too. :)
Hi there!
Offline berserkfan
  • Trade Count: (0)
« Reply #5008 on: Sat, 06 June 2015, 11:30:35 »
any full or nearly full (minus spacebar, minus escape, or minus numpad) set of SA keycaps, in reasonably good condition.
I received a request so am inquiring. Keycaps have to be used in an office where serious work is done, so they must all be the same colour. IE no WASD a different colour, no 1970s retro, no weird insignas like in the Commando set.
Want to know a ballpark price before I make a classifieds post.
Offline halfkiller
  • Trade Count: (0)
« Reply #5009 on: Sun, 07 June 2015, 08:25:00 »
Hi, I just picked up this Model M (Qwertz Lazout) at a local Fleamarket for 4 Euros (YOU CANNOT GO WRONG FOR 4 EUROS XD), and I was wanting to know if anyone knows how much this model is worth ?
I have done some looking on eBay and I tend to find them on eBay, but most of them are made in the UK and not the USA.
I will add photos of the keyboard as well as the sticker on the back of the board.
I was guessing around 30-50 euros ( 32-52 USD).
Many thanks,
HK
Offline heedpantsnow
  • Trade Count: (1)
  • Old enough to know better
« Reply #5010 on: Sun, 07 June 2015, 14:07:19 »
Price check on Poker X.
Stock case, mint.
Stock caps, unused.
Brown switches, used but good.
I'm back.
Offline Blaise170
  • Trade Count: (0)
  • ALPS キーボード
    • XYZ
« Reply #5011 on: Sun, 07 June 2015, 15:36:08 »
What would be a fair price on Fujitsu Peerless? Something like $20 shipped? And would you all consider it a mechanical keyboard?
Offline slip84
  • Trade Count: (0)
  • GUYDUDE MAGICIAN
« Reply #5012 on: Sun, 07 June 2015, 15:41:29 »
Assembled Tex Yoda with MX blues; however, small ding int he case (front right corner) and stock caps are a little janky. USPS did me the favor of crushing one a little. I think it's the "1" key and it's broken on the back. Still mounts and only noticeable from the back.
Apart from that, it's assembled, working, and quite lovely.
Price?
Offline berserkfan
  • Trade Count: (0)
« Reply #5013 on: Sun, 07 June 2015, 21:16:59 »
Many thanks,
HK
Regardless of what people tell you that it's worth I recommend that you keep this board. It's not extremely rare enough to be worth tons of money, but is uncommon enough that if you or some close personal friend should want a German layout model M in future, would save you the time to find one again.
  • Trade Count: (0)
  • Frenzy Classic.
« Reply #5014 on: Mon, 08 June 2015, 03:51:24 »
Stock case, mint.
Stock caps, unused.
70-80$.
Offline halfkiller
  • Trade Count: (0)
« Reply #5015 on: Mon, 08 June 2015, 07:52:17 »
Many thanks,
HK
I currently have no need for this keybaord (I already own a Unicomp Model F) and therefore I plan on selling it. :)
Offline roostrc0gburn
  • Trade Count: (0)
  • its just plastic
« Reply #5016 on: Mon, 08 June 2015, 14:44:56 »
i got no response last time, so let's try again -
i have a corsair k95, non-rgb, white backlit, with the old badge style and black vortex pbt/pom backlit keys and max keyboard 50A, 0.4mm o-rings.
think i could get $100 for this? i am hoping to sell/trade this and some pp for a filco. any suggestions?
Offline halfkiller
  • Trade Count: (0)
« Reply #5017 on: Tue, 09 June 2015, 03:24:41 »
So I would still like to know how much it is worth, or an estimate . :p
Offline Nover
  • Trade Count: (0)
« Reply #5018 on: Tue, 09 June 2015, 03:46:44 »
Depending on condition, manufacturer and age, 40-60€. Can net more on ebay if you properly clean it, take great pictures and write a good item description. Also matters when the auction, if it isn't bin, ends. And so on.
SSK, Ducky YOTD
Offline halfkiller
  • Trade Count: (0)
« Reply #5019 on: Tue, 09 June 2015, 07:10:24 »
Vielen Dank!
I recently cleaned each individual key cap as well as the housing.
I will post it on here first prior to posting it on eBay.
Offline sethk_
  • Grand Master Wizard Pizza
  • Trade Count: (0)
  • www.kbdhub.com
    • My webstore
« Reply #5020 on: Tue, 09 June 2015, 10:01:21 »
If I am looking to buy a LZ-MX-Mini, what is a reasonable price?
Offline zenless
  • Trade Count: (0)
« Reply #5021 on: Tue, 09 June 2015, 13:48:44 »
looking at a used (circa 05) PS2 Unicomp classic 101 key, wondering what a good price would be for it.
Offline Jixr
  • Trade Count: (1)
« Reply #5022 on: Tue, 09 June 2015, 16:27:38 »
I have a built up GON60 pcb that i'm not using anymore, was thinking of selling it.
its all soldered up and ready to go. no stabs though.
Offline Prelim
  • Trade Count: (0)
« Reply #5023 on: Tue, 09 June 2015, 16:36:55 »
I guess $30 or so just for the pcb
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
Offline ceflame
  • Trade Count: (0)
« Reply #5024 on: Tue, 09 June 2015, 17:04:45 »
Really? I would say AT LEAST retail price, if not a bit extra considering GON's shipping time and he already soldered on the diodes/resistors I'm guessing.
Offline JonasDK
  • Trade Count: (0)
  • Let me poo on you
« Reply #5025 on: Tue, 09 June 2015, 17:54:19 »
Well, I recently bought a G81-3098SAD for the keycaps. I know these are PBT dyesub, but how much are they really worth?
  • Trade Count: (0)
« Reply #5026 on: Tue, 09 June 2015, 17:58:46 »
Since it's ISO (AZERTY?), not a whole ton.  I think I remember Photeqk saying in the $35-50 range for them.  ISO really isn't desirable and, from what I remember, they're pretty common.  ANSI are the expensive ones.
Offline Nover
  • Trade Count: (0)
« Reply #5027 on: Tue, 09 June 2015, 18:01:06 »
~40-50€ usually. More if in superb condition.
It's Iso-DE @Nubbi
SSK, Ducky YOTD
  • Trade Count: (1)
« Reply #5028 on: Tue, 09 June 2015, 18:57:29 »
I'd say so. Add ~20% for scarcity and labor.  Don't forget the cost of the switches.
I'm back.
Offline Jixr
  • Trade Count: (1)
« Reply #5029 on: Wed, 10 June 2015, 08:41:26 »
yeah, not many people want to pay $25 shipping from gon to the US, also i have a plate and switches for it.
Offline nova779
  • Trade Count: (0)
« Reply #5030 on: Wed, 10 June 2015, 10:26:11 »
What would a bag of around 80 harvested mx blacks be worth? They were harvested from a PLU ML-87 and some have bent pins that I was unable to bend back but they still came out of the PCB so it may or may not be an issue. Also have the tkl plate from that which is orange if it would be worth anything.
Offline Blaise170
  • Trade Count: (0)
  • ALPS キーボード
    • XYZ
« Reply #5031 on: Wed, 10 June 2015, 11:41:32 »
$0.20-0.35 depending on how old they are.
Offline nova779
  • Trade Count: (0)
« Reply #5032 on: Wed, 10 June 2015, 14:50:41 »
Is that for all of them or just a piece?
  • Trade Count: (0)
« Reply #5033 on: Wed, 10 June 2015, 15:02:36 »
per switch
  • Trade Count: (1)
« Reply #5034 on: Wed, 10 June 2015, 18:24:51 »
PLU is my fav budget tenkeyless. Great board and construction is quite good for the price.
I would not offer the switches with bent pins for sale though.
I'm back.
Offline radio_killah
  • Trade Count: (0)
  • Chinchillin'
« Reply #5035 on: Wed, 10 June 2015, 19:46:55 »
How much for a hhkb pro2 from 2010. No box, with green wasd, green enter, and red esc key.
Offline Fullcream
  • Trade Count: (0)
« Reply #5036 on: Wed, 10 June 2015, 20:13:56 »
PRO 2 TYPE S
Arrived yesterday, opened box, plugged in to make sure it's working then put back in box.
  • Trade Count: (1)
« Reply #5037 on: Thu, 11 June 2015, 08:39:46 »
What's an Olivetti with ANSI dyesubs worth?
Offline metal369
  • Trade Count: (1)
  • Singlepath
« Reply #5038 on: Thu, 11 June 2015, 08:47:14 »
In my opinion, Olivetti dyesub's worth is hang on its seller's mind.
Hi there!
  • Trade Count: (0)
  • Frenzy Classic.
« Reply #5039 on: Thu, 11 June 2015, 09:03:03 »
Lol. Photekq seems want know value  :))
Offline metal369
  • Trade Count: (1)
  • Singlepath
« Reply #5040 on: Thu, 11 June 2015, 09:09:45 »
yeah, it means just priceless. lol
um... I heard Cyrillic Dyesub is around 800$. Olivetti will similar to it.
Hi there!
  • Trade Count: (1)
« Reply #5041 on: Thu, 11 June 2015, 09:19:38 »
Cyrillic's definitely a lot more valuable than Olivetti. I was thinking much lower :/
Also, this is a set that's been used for 3years+, not a NIB one.
  • Trade Count: (0)
  • Frenzy Classic.
« Reply #5042 on: Thu, 11 June 2015, 09:35:21 »
Maybe  it's more valuable than 1000$.
Offline azhdar
  • Praise the AZERTY god
  • Trade Count: (0)
« Reply #5043 on: Thu, 11 June 2015, 09:47:53 »
Maybe a NIB would go for that high, but 3years used ?
Maybe 200-300$ ?
Azerty Propagandiste
Offline Hzza
  • Trade Count: (0)
« Reply #5044 on: Thu, 11 June 2015, 10:04:25 »
It's always really hard quoting prices for those kind of things so I'll just leave this here and move on.
The thing with Cherries is that you have two markets. Sane people and insane people.
:D
  • Trade Count: (1)
« Reply #5045 on: Thu, 11 June 2015, 10:17:11 »
:D
I was thinking about $150-200 for sane
$300-350 for insane
Offline Hzza
  • Trade Count: (0)
« Reply #5046 on: Thu, 11 June 2015, 10:21:33 »
Sounds reasonable to me.
Offline epzy
  • HHKB Fiend
  • Trade Count: (1)
  • ded
« Reply #5047 on: Fri, 12 June 2015, 01:35:27 »
1. 10th ae rf 55g which is missing 10 keycaps (actually, the stems are just broken off, I still have the keycaps)
2. digil0g rf aluminium case
how much?
Offline Rotaku
  • Trade Count: (0)
  • Too Based
« Reply #5048 on: Fri, 12 June 2015, 15:27:08 »
Any idea how much this lynk model m is worth? I know it's missing some caps, but i put in a teensy myself and it's using soarer's converter, i just don't really know how to price it because of the missing caps
Not toooo active on GH anymore, if you need me, shoot me a PM on Reddit! /u/IchibanXD
Offline cs16wos
  • Trade Count: (0)
« Reply #5049 on: Fri, 12 June 2015, 16:30:06 »
What is Lambda (Half-Life) keycap worth?
