Author Topic: Build your own case!  (Read 23644 times)
Offline Fullcream
« on: Thu, 16 June 2016, 14:01:35 »
Hello. So I built my own poker/universal mount hhkb case and just wanted to share it with you because I'm really excited about it. Here it is finished:
I guess here is a bit of a rough diy guide.
So think about what you know will look cool!
Starting with a plastic generic Aliexpress case I drilled holes and zip-tied some piece of Aluminium flat to it for more angle.
(don't worry I cleaned off that glue)
With an A3 sized sheet of 3mm acrylic I did some measuring and cutting.
Glue the pieces on! Woohoo!
(all the yellow that you see is the color of the glue I used)
Find some things lying around and glue them in for weight. Cool!!. Oh yeah at some point I measured and cut the rear piece and hhkb blockers. Must have forgotten to take pics. Soz! Lol
Measure and cut out a hole for usb. I first drilled a hole then took my time with a square file.
Bog it up. Haha messy.
Sand/file. This process took the longest. Keep it square and clean! I didn't want rounded edges.
Undercoat really helps to hide imperfections!
Gon waiting, just a little while longer m8! Oh btw thanks Leandren! This was from R4
Paint dry.
A few minor imperfections. Actually the most obvious ones are just in the paint and I'll be going back to fix them soom when I get time.
« Last Edit: Thu, 09 March 2017, 22:01:00 by Fullcream »
Re: Build your own case!
« Reply #1 on: Thu, 16 June 2016, 14:06:39 »
Masterful. Holy ****.
Offline chuckdee
« Reply #2 on: Thu, 16 June 2016, 15:09:47 »
Now that is cool.  Great work!
Offline xondat
  • i'm not a star
« Reply #3 on: Thu, 16 June 2016, 15:13:03 »
Absolutely brilliant.
Offline dgneo
  • Supervillain
« Reply #4 on: Thu, 16 June 2016, 15:15:38 »
Offline Zorberema
  • IG: @ZorbCaps
« Reply #5 on: Thu, 16 June 2016, 15:45:10 »
Those weights though, haha! Really awesome job, looks very nice and smooth! :)
Offline funderburker
« Reply #6 on: Thu, 16 June 2016, 15:46:10 »
Really skillful stuff!  :thumb:
Keyboard design by Skepur
Offline evangs
  • TheVan
« Reply #7 on: Thu, 16 June 2016, 15:53:15 »
I'm following along the whole way saying to myself 'he done ****** up now' and then there is this beautiful case at the end..... I'm just like  :eek:  :thumb:
seriously nice work!
Offline Fullcream
« Reply #8 on: Thu, 16 June 2016, 15:57:31 »
 :) oh there was quite a few mistakes. I just did my best to hide them all.
Offline b4d_tR1p
« Reply #9 on: Thu, 16 June 2016, 17:17:18 »
wow!  :thumb:
139949-0
« Last Edit: Thu, 16 June 2016, 17:22:44 by b4d_tR1p »
-----BEGIN GEEK CODE BLOCK-----
Version: 3.1
GCS/CC d-(--)>---x s:-(--)>--- a C++++(++++)>++ UBLC++++(+++)$>++ P++ L+++++(+++++)>+++++ E---(---)>--- W+++(+++)>+++ N+++ o++ K-- w O M++ !V- PS+++(+++)>+++ PE+++(+++)>+++ Y+++(+++)>+++ PGP++ t+ 5 X+ R tv- b++ DI++++ D+++ G++++ e+++ h- r++ y+++
------END GEEK CODE BLOCK------
Offline davesantos
« Reply #10 on: Thu, 16 June 2016, 17:50:55 »
Looks great. This is thrifty DIY!
Offline Fullcream
« Reply #11 on: Thu, 16 June 2016, 20:37:34 »
Gonna start on the next one very soon. Will have a wider bezel and wkl blockers.
« Reply #12 on: Thu, 16 June 2016, 20:42:54 »
Gotta love that scrap metal ballast.
- D Trump 2026-10-24
Offline juahenza
  • DoSmallThingswithGreatLove
« Reply #13 on: Thu, 16 June 2016, 20:50:32 »
Undercoat really helps to hide imperfections! Haha this is great because it was far from perfect.
Paint dry.
This is really good efforts. Well done  :thumb:
456GT | TGR Jane CE | Dolphin v2 | Whale | 360c | LZ FE | LZ IRON | TX-CP | Varmilo VA87M | HHKB P2 | IBM SSK P.1397681| IBM Industrial SSK P.1395682 | VE.A | Realforce 87u | Datamancer Streamline TKL | Datamancer Mechinist TKL | TANK v1 | RAMA M-4 | Realforce 108UW-HIPRO
Offline Leslieann
« Reply #14 on: Thu, 16 June 2016, 22:38:07 »
The difference between a hack and an artist is that the artist knows how to hide their mistakes.  :))
Nice work!
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline dannrawr
« Reply #15 on: Fri, 17 June 2016, 01:01:04 »
WTF any Bruce, Cosmonauts
« Reply #16 on: Fri, 17 June 2016, 01:02:02 »
Looks sharp! ;)
What do you use as case feet?
Offline Fullcream
« Reply #17 on: Fri, 17 June 2016, 02:57:37 »
Thanks. I just use the stick on rubber feet that came with the generic case.
« Reply #18 on: Fri, 17 June 2016, 04:15:06 »
Probably the best post I've seen in a while. Well done
« Reply #19 on: Mon, 20 June 2016, 16:12:58 »
Absolutely flawless.
Offline tung91
« Reply #20 on: Mon, 20 June 2016, 18:39:17 »
Awesome, i also have black blank keyset, will try this ! Thank for your tutorial :thumb:
Offline Fullcream
« Reply #21 on: Wed, 22 June 2016, 03:52:28 »
no problem! and thanks for the feedback from users.  Next one will actually be more of a proper tutorial.
