Author Topic: Tt eSPORTS KNUCKER ("Tt-Plunger switch technology")  (Read 3265 times)
Offline Bullveyr
« on: Wed, 30 May 2012, 05:17:42 »
Press Release
Product Page
[ Attachment Invalid Or Does Not Exist ] 51860[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 51861[/ATTACH]
Collaborated and co-designed by Tt eSPORTS Team Tt Apollos pro-player Hermes, KNUCKER pro-gaming keyboard is unique in its unprecedented key-switch design. Installing Tt-Plunger switch technology, developed by Tt eSPORTS’ Key-switch Product Development workshop, KNUCKER is bringing the ultimate key response experience simulating to mechanical switch, but with extreme ease and comfort.
KNUCKER pro-gaming keyboard is installed with the plunger-switch that simulates mechanical switch feedback, but with extra elasticity and comfort.
Color : Black
Interface : USB, PS/2
Operating System : Windows 7/Vista/XP
Switch Type : Plunger Switch
Switch Keystroke Lifecycle : 15 million keystrokes
S4Key-Function Design : Repeat Rate 1x, 2x, 4x, 8x.
Anti-Ghosting Keys : 12 (USB), 16 (PS/2)
Weight : 880g
Body Dimension : 450*185*28.5mm
On-Board Wrist Rest
1.8m Cable Length with Gold-Plated USB
Quote from: ripster;185750
Mechanical switches are mechanical.
Offline laffindude
« Reply #1 on: Wed, 30 May 2012, 06:17:45 »
I've seen those before somewhere. They're just rubber dome over membrane under that plunger.
Offline laffindude
« Reply #2 on: Wed, 30 May 2012, 06:28:34 »
Offline Bullveyr
« Reply #3 on: Wed, 30 May 2012, 07:25:59 »
Quote from: laffindude;603745
http://www.i-rocksusa.com/products/KR-6260-BK.html Well, there you go.
Thx, not that I expected something from them, just never seen them before.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #4 on: Wed, 30 May 2012, 10:39:32 »
Only good TT board is Meka G1. They should have more board made by costar than all other crap they put their name on.
Offline hamza_tm
« Reply #5 on: Wed, 30 May 2012, 10:50:46 »
Meka non-G series is I'm pretty sure costar made as it was wonderful quality when I had it. Fabulous.
Offline laffindude
« Reply #6 on: Wed, 30 May 2012, 11:39:22 »
Your keyboard radar needs adjustments. Meka is an i-Rocks. G-unit is most likely an iOne.
