Author Topic: Stem Question  (Read 1979 times)
Offline jcrouse
Stem Question
« on: Fri, 01 June 2012, 07:44:18 »
I am looking for a bunch of cheap stems for cherry MX switches, a couple at first for testing an idea and then probably 250 or so. All I really care about is that a Cheryy MX cap fits on them, color / sytle is not important. What would be the best way to obtain these, a WTB post in the classifieds forum or is there a place that sources new stems at a reasonable price, say .08 or .10 cents, something like that.
Thank you,
John
Offline Djuzuh
Stem Question
« Reply #1 on: Fri, 01 June 2012, 07:45:25 »
I'm interested in this too !
Offline Lanx
Stem Question
« Reply #2 on: Fri, 01 June 2012, 09:21:30 »
yea a wtb would be your best bet, or to harvest from used/cheap cherry boards
another option is to buy individual keyswitches from mouser
http://www.mouser.com/Cherry-Electrical/Electromechanical/Switches/Keylock-Switches/_/N-5g2uZ1z13w7p/
you can basically figure out which ones are blue/brown and black.
Offline IvanIvanovich
  • Mr. Silk Underwear
Stem Question
« Reply #3 on: Fri, 01 June 2012, 09:32:38 »
If all that matters is keycaps fitting, you can often pick up lots of G81 MY boards for very cheap on ebay ~$7/board.
Offline jcrouse
Stem Question
« Reply #4 on: Sun, 03 June 2012, 13:55:51 »
Quote from: lysol;605543
Now, that suggestion has some merit. Can anyone provide a pic or 2 of the back side of a Cherry MY stem. Not the cross (that goes in the cap) but the other end with the stem actually removed from the switch?
Thank you,
John
