Author Topic: I'm confused... No stabilizer support on keycaps?  (Read 4291 times)
Offline square965
« on: Fri, 01 June 2012, 12:40:18 »
[Solved]
I just decided to buy a blank white 104 keycap set from WASD a few days ago. It arrived in the mail and as I try to put them on, I realize that there is no place for the stabilizer bars on the keys. Is this normal? There were no options or anything on the web site when I ordered.
http://i.imgur.com/1pvxs.jpg
« Last Edit: Fri, 01 June 2012, 12:47:40 by square965 »
Offline shawn o
Offline metafour
« Reply #2 on: Fri, 01 June 2012, 12:44:27 »
Do you have a keyboard with Costar stabilizers? Are you referring to needing these?
http://www.wasdkeyboards.com/index.php/cherry-mx-keycap-stabilizer-insert.html
Offline square965
« Reply #3 on: Fri, 01 June 2012, 12:44:35 »
Yep... I didn't realize they wouldn't come with the caps.
Offline square965
« Reply #4 on: Fri, 01 June 2012, 12:47:18 »
Looks like I can just remove them from my old caps though.
Thanks guys, sorry for the stupid question.
Offline megnin
  • Topre, or not Topre? That is the question.
« Reply #5 on: Sun, 03 June 2012, 09:27:05 »
Not a stupid question at all.  If you bought a "naked" keyboard without any caps to scavenge the inserts from then you would be in a pickle until you got some of those inserts.  It might not be a bad idea to get some extras if you replace caps a lot.  They are thin in places and can be broken if your aren't careful while removing them from the cap.  I've broken them.
“The only difference between me and a madman is I'm not mad." -- Salvador Dali
